Needing Help
  • 1 Post By NitroPT
Old 18 May 2017, 11:49 pm
Default Needing Help
I'm working on a friends 04 pt non turbo manual trans. It died on her and had it towed to me. It cranks over but no start. Timing belt is good and so is fuel pressure, but no spark. When I went to check for any codes, I noticed that the service engine light does not come on at all, ever. All fuses and relays are good. The instrument cluster is sealed so theres no way to check the bulb. Any help will be greatly appreciated .
Old 19 May 2017, 08:44 am
VsandFords's Avatar
Default Re: Needing Help
Welcome to the forum from Texas.
With a no spark issue, I would start with checking the coil pack and working back from there. Check the wire connection and make sure it not broke and come loose. Check for voltage going to the coil with a multimeter.
Please go to the new members section and introduce yourself when you have a sec.
Old 19 May 2017, 10:36 am
The service engine light might be covered with a piece of black tape.
Are you getting any engine trouble codes with an OBDII Scan Tool?
Try pulling the camshaft sensor wire connector off the sensor, start the engine and see if the code for it comes up if you are not getting any engine trouble codes.
Old 20 May 2017, 02:21 pm
No tape on light, There were no codes, unplugged cam sensor and then got the code for it. Still no spark. crank sensor and coil pak tested good. Getting a steady 5 volts on 1 and 3 wires to the cam sensor. service manual is no help
Old 20 May 2017, 02:58 pm
Originally Posted by VsandFords View Post
Welcome to the forum.
What he said ^^^^^^^^^^^^^^^
I will tell you that if the engine is turning over and not starting there will be a few DTCs. Unless there is a harness to PCM problem, a fried ECM or the diagnostic connector is not communicating with your Diagnostic tool.
VsandFords likes this.
Old 20 May 2017, 04:03 pm
Make sure the ignition coil wire plug is not switched with the camshaft sensor plug.
Old 22 May 2017, 03:51 am
it was driving down the road then died on her so I seriously doubt she switched plugs but i'll check just to be sure.
Old 22 May 2017, 04:03 am
Can't find the new members section you're referring to, still trying to figure out how to navigate this site.
So let me say now hello and greetings one and all to Everybody. I'm just an old-school grease monkey trying to rebuild my life after a really bad divorce. Any help is greatly appreciated.
Old 22 May 2017, 04:10 am
Hello and thanx for replying. I pull the plug on the cam sensor and cranked the engine and sure enough, I got a code for it. Plugged it back in cleared the code, cranked it again, still no spark and no codes
Old 22 May 2017, 10:01 am
This might help...
PT CRUISER: I HAVE REPLACED COIL PLUGS AND WIRES
Hello new guy here.. needing some advice cruiserslaw General Turbo Discussions 31 02 May 2017 07:34 pm
Military man needing help sonofkri General PT Cruiser Discussions 30 06 Sep 2015 01:10 am
New Member Needing Help Barbie Welcome New PT Cruiser Members 15 13 Aug 2015 07:47 pm
help... i'm needing some advice! supgrrl Tech & Performance Forum 5 09 Feb 2010 06:40 pm
