Fuel pressure check??
Old 22 May 2017, 09:32 am
Default Fuel pressure check??
06 PT..got a fuel pressure guage kit and my PT has the line back by the fire wall.I disconnected it there.(were it connects to the fuel rail line) clamped my guage on there and with the key on its reads 60lb and when cranking still 60lb of pressure is this enough and should the pump be ok?
or do I need more pressure? thanks
Old 25 May 2017, 08:47 pm
Default Re: Fuel pressure check??
That's perfect. Factory preset is 58psi. Does your kit have fittings to allow you to connect there as a pass-thru so you can monitor pressure while running? I doubt your results will be much different, but if you are maintaining 58psi (approx) while running, then you are definitely good!
Clogged fuel filter, low fuel pressure or what? Gilgrin Tech & Performance Forum 8 01 Jun 2016 04:57 am
What's the minimum fuel pressure for car to run? unioncreek Tech & Performance Forum 5 27 Jul 2012 03:40 pm
fuel pressure check OurPTGT Tech & Performance Forum 7 27 Jul 2012 09:25 am
Fuel pressure regulator. Where it be at? Skye Tech & Performance Forum 3 23 Aug 2010 03:59 pm
Fuel pressure gauge PT GT Turbo Performance 1 14 Jun 2003 09:15 pm
