Need help. Mechanic Blocked Off EGR Valve after Timing Belt Replacement?
Old 27 May 2017, 11:02 am
pmcruiser's Avatar
Default Need help. Mechanic Blocked Off EGR Valve after Timing Belt Replacement?
My son had his timing belt replaced by a "so called" mechanic on his 2001 PT Cruiser N/A. We brought him all the parts but for some reason he used a 2003+ timing belt kit and gave us back the 2001 gates timing belt kit.
His gas mileage has plummeted big time to like 10/12 MPG. We did find after snooping under the hood countless times that the EGR was blocked off with a homemade cardboard block off gasket. We removed the block off and still no luck getting MPGs back.
I know the 2003+ PT's had no EGR where as the 2001-2002 did. Again, not sure why he used the 2003+ timing belt kit but I "think" whatever reason he plugged the EGR is why the MPG's have suffered tremendously ever since he got the car back. Of course the mechanic is nowhere to be found.
I'm trying to figure out why he would have plugged the EGR valve after the timing belt change and would like to reverse it if possible.
Could really use some help on this one guys! My son is a couple hours away so I would like to be armed and ready to get this finished up for him.
2001 LE 2.4L N/A
5 Speed Manual | Borla S/S Dual Exhaust | K&N Drop-in Filter
CarDomain Page
http://www.cardomain.com/ride/392318...sport-wagon-4d
Old 27 May 2017, 11:38 am
Default Re: WTF? Mechanic Blocked Off EGR Valve after Timing Belt Replacement?
There's possibly two differences in the newer timing belt kit. At one point the belt tensioner was changed and the top part of the cover was a little different. When my mechanic used the kit I brought him for my 2001 he had to slightly modify the cover to make it fit. He made no reference to a different kind of tensioner. Neither of these would make a difference in gas mileage.
You said you took off the block from the EGR and made no difference in your son's mileage so something else might have been moved or altered. Do you still have the EGR pipe in the back of the upper manifold?
...and is it still connected at the bottom to the EGR valve?
He shouldn't have gone near it but check the PCV valve.
Old 27 May 2017, 04:28 pm
rob302's Avatar
Default Re: Need help. Mechanic Blocked Off EGR Valve after Timing Belt Replacement?
I would want to know what trouble codes are stored. EGR it's more for emissions and has little to no effect on MPG. i think your MPG problem lies elsewhere.
Old 27 May 2017, 06:51 pm
Handy_Cruiser's Avatar
Yep,
If me, I'd do like Rob suggested and read whatever trouble code I have. Then I'd use my code reader to clear the codes, drive the car until the check engine light returns and then read the codes again. This will likely help tell the story.
I'd also be questioning that mechanic really hard to tell exactly why he blocked off the EGR.
Old 28 May 2017, 04:34 am
Sounds to me like it's not timed correctly.
Timing belt/ possible bent valve? CanadianJoey General PT Cruiser Discussions 11 23 Jul 2014 08:41 pm
Mechanic Says Timing Belt is About To Go...? Kaylad8528 Tech & Performance Forum 10 19 Oct 2012 08:59 am
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
How much is timing belt/water pump installed by mechanic? BrianW General PT Cruiser Discussions 13 03 Nov 2010 09:19 pm
Looking for Bronx/NY Mechanic to perform Timing Belt Change djlou Northeast PT Forum 12 09 Sep 2008 03:52 pm
