2001 PT Cruiser not starting
Old 30 May 2017, 05:36 pm
Default 2001 PT Cruiser not starting
About 2 months ago I was going down the road and the car just died and wouldn't start back. The issue ended up being wires that had melted so the entire wire harness was replaced but also at the time the crankshaft sensor was broken so it was also replaced (OEM part, not aftermaket).
This time the car has been running fine but two days ago when it was last started it acted like it didn't want to start but after a couple of tries it started and I drove over an hour back home with no problem. Today I went to start it and nothing. It turns over and acts like it wants to start but there's no fire.
It is showing a p0320 code again which is what it showed last time.
The car has about 130,000 miles on it. The timing belt and starter were both replaced right before I bought it at 90,000 -ish miles.
I can hear the fuel pump engage and there's no check engine light or anything else that indicates a problem other than the fact that it doesn't start and the code.
We've went back and checked all of the wires again just in case but I'm at a loss of where to start looking now other than maybe replacing the camshaft sensor.
Old 30 May 2017, 05:45 pm
Default Re: 2001 PT Cruiser not starting
Welcome to the forum.
Check to make sure you don't have wires coming from the camshaft or crankshaft sensor rubbing on the axle or frame causing the wires to short to ground or each other. Double check the wires going to the crankshaft sensor. Check the wire for continuity.
P0320 - No Crank Reference Signal to PCM
Possible Causes:
1. Crankshaft Sensor signal circuit open or grounded
2. Crankshaft Sensor VREF circuit open or grounded
3. Tone wheel or flex plate damaged or erratic CKP Sensor signals
4. Crankshaft Sensor is damaged or has failed
5. PCM has failed
Old 30 May 2017, 05:49 pm
rsrocket1's Avatar
Originally Posted by ajtn View Post
It is showing a p3020 code again which is what it showed last time.
You're sure it's not P0320?
That's a crankshaft position sensor fault.
Did you try to simply disconnect, clean the terminals and reconnect it?
If it's truly P3020, sorry I can't help.
Old 30 May 2017, 08:03 pm
It is P0320, I just made a type
The crankshaft position sensor was just replaced when I replaced the wiring for it so I'm doubtful it's the actual part.
Old 30 May 2017, 08:05 pm
The last time it did this it was the wiring that had fell and melted so I replaced the entire harness and attached it up out of the way.
When it did it this time the wiring was the first thing I checked.
Attachment 22409
Possible Causes:
5. PCM has failed
Old 30 May 2017, 08:45 pm
Is this harness you got to replace the original one a brand new one? If not I would check the wiring.
If the wiring is okay I would double check the crankshaft sensor. Some members have had brand new crankshaft sensors fail.
Have you checked to make sure you don't have oil in the PCM plug that the crankshaft wire is in?
2001 PT Cruiser not starting..my fault..any ideas on what to look for to fix it? trose848 Tech & Performance Forum 7 08 Oct 2011 03:03 pm
2001 cruiser not starting KingJames Tech & Performance Forum 2 21 Jun 2011 10:10 am
Help with starting 2001 Pt Cruiser Doc60 General PT Cruiser Discussions 10 10 Jun 2010 07:27 am
Pt Cruiser Not Starting teknoron Tech & Performance Forum 8 11 Sep 2008 02:04 pm
2001 Starting question Circuitlaif Tech & Performance Forum 16 29 Mar 2004 11:33 am
