how do I address this code?
  • 1 Post By rob302
Old 02 Jun 2017, 07:56 am
Default how do I address this code?
Just got my pt yesterday. had a code for O2 sensor bank one srnsor 2 .p0141.heat circut. I cleaned the connection and cleared the code, drove 10 mi and no code yet..what is the common thing here, what do I expect?, thanks for any insight.
Old 02 Jun 2017, 08:18 am
Default Re: how do I address this code?
Sometimes the O2 heater circuit shorts out blowing fuse #13. Suggest waiting to see if the code comes back. Did you reset the code with an OBDII Scan Tool?
Old 02 Jun 2017, 08:36 am
yes with the tool. where is the 13 fuse located?
Old 02 Jun 2017, 08:41 am
reading that the 13 fuse is fuel pump?
Old 02 Jun 2017, 08:48 am
rob302's Avatar
not sure of your level of tech.. but to check the heating element, you should have 4-6 ohms between pins 1 and 2 on the o2's connector, checking the sensor connector with the sensor unhooked.
you night also check the ground wire at the body... which i cant seem to find quickly in alldata right now. grumble. there's groups of grounds in the inner fenders, and one underhood near the ecu
Old 02 Jun 2017, 09:01 am
I heard there is a fuse?..any ideas on the location and number?
Old 02 Jun 2017, 12:50 pm
SPLNeon's Avatar
Someone mentioned fuse #13 above.?!
Disconnect the negative terminal then clean the cluster of grounds on the inner left fender . I don't have an airbox but I'm certain it will need to be removed to access it.
Give that a try.
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.89at 115mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
New web address and new products dicenstuff Vendors & Buyers Forum 0 14 Aug 2002 10:13 pm
