2003 PT - Need HELP with Timing belt & T350 Trans maintenance
Like Tree8Likes
  • 1 Post By rckstein
  • 1 Post By CREWZIN
  • 2 Post By rob302
  • 1 Post By pasadenahotrod03Dreamer
  • 1 Post By Busted_PT
  • 2 Post By dsab
Old 04 Jun 2017, 10:02 am
Default 2003 PT - Need HELP with Timing belt & T350 Trans maintenance
All,
The Specs - Wife's 2003 Non turbo PT Cruiser limited with 175,000 miles
T350 manual transmission
Issues - Timing belt needs replacement
Transmission leaks from housing and needs to be removed/repaired
Clutch replacement - 175K on original
Oil leaks I believe from, Oil pan, crank & axle seals and valve covers
Airbag light stays on.
I have tools, dry place to work and the wife wont need it for a few weeks.
Any advice, suggestions, links, videos, what to replace or look for while performing this major task would be appreciated. Also any recommendation on part brands. I believe I will try and purchase most of the parts from rockauto.
Please forgive me for mainly asking for help and not giving much on this blog. For over five yrs now I have been caring for my 87yr old mother who is now in the later stages of Alzheimer.
Thanks again in advance..
Howard Tiger Mims
Old 04 Jun 2017, 10:29 am
rckstein's Avatar
Default Re: 2003 PT - Need HELP with Timing belt & T350 Trans maintenance
You've got quite a list of issues going on with the PT.
Is this still the original timing belt?
For the timing belt job, at the same time while the area is torn apart, you should replace: timing belt, water pump, tensioner, idler pulley, cam seals, crank seal, center motor mount with new bolt.
Sorry to hear about the situation with your mother.
dsab likes this.
Old 04 Jun 2017, 10:51 am
In the HOW TO section, we have about 5 threads on the timing belt. You might want to look over a couple of them for reference before trying the job. Sorry about Mom, went through that while over in England with my Mother-in-law.
HOW TO's
howardmims likes this.
Old 04 Jun 2017, 11:31 am
rob302's Avatar
I've had the trans apart. Have a look here, lmk if you need anything answered. i killed it.
Busted_PT and howardmims like this.
Old 06 Jun 2017, 11:41 am
I just did the job on my 07 Pacific Coast Highway Street Cruiser. It takes time but I got it done once I rounded up the correct tools.
I replaced the timing belt belt, tensioner, idler pulley, cam. Seals, front motor mount and bolt, and upper and lower torque arms.
I spent two weeks off and on due to weather and baby sitting grand kids. I think I did about twelve actual work hours but next time am sure it will be a two day job. I'm working in the driveway with jackstands and hydraulic jack.
Old 07 Jun 2017, 11:30 am
As CREWZIN said look at the how to,s. The harmonic tips thread is a good place to start. Will compliment the other belt threads there. Don't forget to photo the job as you go. And especially the marks before you close up.
Old 07 Jun 2017, 10:10 pm
Other than being a bit tight to work on the timing belt and the related parts does take a bit of time to complete. If you don't have one I would suggest getting a good harmonic balancer puller. If you don't want to purchase one your local parts store should have one you can rent.
I looked around a bit for some videos that might help and found one, it's actually a series for the timing belt. I scanned through them and they cover the job well. Here's the link
I didn't disconnect my AC lines when I did mine so it'll take a little bit longer to work around them
howardmims and JDK52 like this.
2002 Limited Edition 2.4 Auto with 177k Miles
Old 28 Jun 2017, 08:02 am
Thanks for the response... Is there any A/C maintenance I should perform while its apart.
Thanks again for the help.
Mims
Old 29 Jun 2017, 02:55 pm
rcktpwrd's Avatar
Mims
If the a/c is currently working properly don't do anything to it.
Joel
www.rcktpwrd.com
Tags
airbag light, clutch, manual transmission, oil leaks, timing belt
drain plug T350 trans wb2kki General PT Cruiser Discussions 4 14 Apr 2014 12:27 pm
2003 Timing belt rp1959 Tech & Performance Forum 4 23 Sep 2010 06:27 am
Timing belt Pt 2003 GT Turbo RSavage Tech & Performance Forum 14 11 Sep 2010 03:27 pm
2003 GT timing belt CherylK Tech & Performance Forum 8 19 Oct 2009 07:51 am
Maintenance at 120K+ (not knowing previous owner/ cam position sensor vs timing belt) AstitchINtime Tech & Performance Forum 7 04 Oct 2008 12:31 pm
