Wont Start After Replacing Shifter Bushing
Like Tree2Likes
  • 1 Post By Fk5
  • 1 Post By rob302
Old 08 Jun 2017, 12:47 am
Unhappy Wont Start After Replacing Shifter Bushing
My friend replaced the manual transmission shifter bushings on my 02 pt cruiser because it suddenly would not go in reverse and as soon as he was done (from watching him do this, it seemed a fairly easy job) my car would not start. It gets power and can jump from the starter but the ignition does nothing when turned over. Help please. Does anyone have any idea what could have happened or where to look?? Im a single mom and this is my only transportation.
Thank you
Old 08 Jun 2017, 01:24 am
Default Re: Wont Start After Replacing Shifter Bushing
Thank you
Its possible that the shifter cable was not properly reinstalled per the factory shop manual. Did the person working on it have the shop manual?
Is your engine light on? If so what are the engine trouble codes?
Was any wires disconnected by accident when the shifter bushing was replaced?
Old 08 Jun 2017, 06:06 am
rob302's Avatar
Is guess it's just a loose battery cable. I helped a lady with a no-start the other day and it was a loose battery cable
Old 08 Jun 2017, 08:21 am
Does it not start with the ignition on when you jump the starter?
Old 08 Jun 2017, 10:52 am
Fk5 Fk5 is offline
Forget it, I was a bit off. There is a clutch switch, maybe that got knocked loose?
2003 GT 5 speed
162,000 miles
Old 08 Jun 2017, 01:11 pm
Unhappy Re: Wont Start After Replacing Shifter Bushing
Thank you so much for the replys!!
Yes, it jumps from the starter with the ignition ON and from watching him replace the bushings, he just popped out the old rubber bushing and while putting the new rubber bushing in, he was having a hard time getting it in the plastic end of the cable and seemed to be a bit aggressive while attempting to pop that in and it did not appear that he needed to place the cable end on the metal post in any particular way after he was able to get the new bushing in. And no, he did not have a manual and I suggested that maybe there is some sort of switch that engages the ignition when the clutch is pushed in but he said, no, thats not it and left me with a wire to jump start my car from the starter. nice guy huh??
Also, the car interior is all getting power from the battery, including back up lights etc. but could it still be a battery cable issue?
Also, the check engine light is NOT on.
Old 08 Jun 2017, 04:10 pm
LionPT's Avatar
Check the positive battery cable...follow the thin wire to see if it's attached to the starter.
Old 08 Jun 2017, 06:50 pm
Could you tell me where the clutch switch is located so I can attempt to see if he possibly knocked it loose?
Thanks
Old 08 Jun 2017, 06:56 pm
rob302's Avatar
part #11 here. it's under the dash and has a connector with 6 or so wires on it. if you lay on your back and push the clutch pedal up and down you'll see it.
you should stick to the wires on and around the battery. your problem is there as i and others have already stated
Old 08 Jun 2017, 08:43 pm
First thing you should do get a volt meter and check the smallest wire going to the starter from the ignition switch. Post what voltage you have on that wire when you are trying to start it.
shifter bushing wb2kki General PT Cruiser Discussions 5 08 Aug 2014 10:13 am
wont start clifford Tech & Performance Forum 3 21 Jun 2014 02:11 pm
04 pt wont start penstar66 General PT Cruiser Discussions 6 01 Sep 2010 02:27 am
2002 PT Need Help - Replacing "Ball Joint Bushing"? Pied397 Wheels, Tires, Suspension 0 17 May 2010 11:12 am
Installed Hurst Shifter in my GT and now it wont go into reverse! slipstream74 General Turbo Discussions 6 09 Aug 2009 01:24 am
