Gearbox oil?
Like Tree7Likes
  #21 (permalink)
Old 04 Nov 2017, 03:41 pm
Default Re: Gearbox oil?
I ended up using the penzoil syncromesh synthetic when I changed mine. It works good. I'm not going to say that I felt a difference or it shifts smoother or anything, but it went into gears nice and smooth b4, and after the change with the syncromesh so all is good with it. I will definitely use the syncromesh the next time I change as well.
03 gt 5 speed Stage 1
Whoever says "There's no replacement for displacement " obviously underestimates RPM
  #22 (permalink)
Old 04 Nov 2017, 04:23 pm
rob302's Avatar
do you drive like an adult, or do you drive like me?
synchromesh is too slippery for the blocker rings to do their job in a performance application. unless you either drive like a saint, or have a cheaper trans with brass blocker rings, you shouldm NOT be using that as fluid.
synchromesh, oil, etc, is intended for this style synchro:
synchromesh is too slippery for this style synchro:
the top design has no place in a performance trans.
the bottom design stops gears quick when you shift fast. the 4 tabs on the center ring stop the gear, the splines in the center stop the shaft, the teeth on the pair lock together with the slider
the bottom design can't stop the gears quick enough with too slippery of a fluid, even though it feels fine if you drive like a normal adult. they need the added grip, and they need the detergent in the ATF to stay clean and grippy. best way to describe it is to say either fluid will work. the ATF will give you less crunching when speed shifting and the synchro teeth will wear out far slower.
or i could be wrong... i'm not a mechanic, i make signs for a living .....and just happen to break/fix a lot of transmissions
  #23 (permalink)
Old 04 Nov 2017, 11:37 pm
Well here is my two cents. I am now sold on the ATF+4 in my Getrag.
A few weeks ago I was doing the clutch in the PT and I had forgotten to install the pilot bushing in the dual mass flywheel and so I ended up pulling the trans twice. On the second pull, I decided on a whim to change the oil in the trans. The stuff in there was the factory fill I believe because it was burnt and REALLY stunk bad. The trans actually shifted fine and wasn't grinding but it definitely needed to be changed. Anyway I drained it out but because I didn't really intend to change the oil in it, I wasn't prepared. The only oil I had on hand was some regular Pennzoil 5w30. I put that in and drove it for the last few weeks. Well I noticed that the gears wanted to grind a bit more even when I wasn't getting into the gas. Just adult driving.
As well, with the weather becoming colder and colder here I could feel that coldness in the oil too when the trans was cold. So today I decided to change the oil. I bought a 2 litres of Castrol ATF+4 fully synthetic. I thought it would be enough but the trans actually took a bit more. The total was about 2.25 litres. Luckily I had 3/4 of a litre of Mobil Atf+4 Synthetic blend in the back of my car from the power steering filling I had also done when I dropped the trans. It would have been better if it was fully synthetic like the Castrol, but I only had to use a bit of it.
Anyway, the trans really responded well. It really loves that ATF+4 over the 5w30 I had in it previously. The shifting is much improved and no grinding of the gears. It was only one instance, but it made me a believer and I likely won't try running anything different again.
So my vote is for fully synthetic ATF+4
_PTGT03, Carnut and rob302 like this.
  #24 (permalink)
Old 05 Nov 2017, 01:49 am
_PTGT03's Avatar
nice to hear some actual data from experience rather than theory flame wars
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 9800i and Escort Shifter ZR4, front facing traffic camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Electric valve actuated Y-pipe with catalytic converter delete. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
  #25 (permalink)
Old 06 Nov 2017, 08:33 am
Hmm....this could be true.
Attachment 25874
Attachment 25875
Attachment 25876
Attachment 25877
Attachment 25878
Attachment 25879
Attachment 25880
Attachment 25881
Hmm... this could very well be true. I am anything but easy on my pt. I drive the shit out of it. So far I have about 20k on the syncromesh and no issues yet but you have made me worry enough to do some research that's for sure. Thanks rob302 for the info. Good looking out.
Gearbox bush set PTStuart Tech & Performance Forum 4 23 Feb 2015 11:01 am
Gearbox clunking stek2008 General PT Cruiser Discussions 4 07 Oct 2013 08:35 pm
Gearbox replacement swordfish Tech & Performance Forum 2 14 Oct 2010 07:22 pm
Gearbox noise?? siscor Tech & Performance Forum 6 03 Sep 2010 02:24 am
gearbox faults kenjenkins0123 Tech & Performance Forum 3 22 Mar 2009 08:21 am
