Gearbox oil?
Like Tree7Likes
Old 11 Jun 2017, 03:29 am
Default Gearbox oil?
Want to change the gearbox oil in my manual cruiser, thinking about RedLine, any other ideas on which oil's the best for these cars?
Old 11 Jun 2017, 05:58 am
Default Re: Gearbox oil?
I can't make any suggestions on this one, ed. Mine is an automatic and uses ATF+4.
Old 11 Jun 2017, 01:15 pm
Do not use gear oil. It is too thick
"Shop Manual "TRANSMISSION FLUID"
Mopart ATF+4 (Automatic Transmission Fluid- Type 9602) is required in the 41TE automatic. ..."
"G288 and T350 Manual transaxles require the use
of Mopart ATF+4 (Automatic Transmission Fluid)
Handy_Cruiser likes this.
Old 11 Jun 2017, 06:01 pm
rcktpwrd's Avatar
Post Re: Gearbox oil?
The early manual transaxle requires special MOPAR lubricant:
Mopar Manual Transaxle Lubricant part# 04874465
Joel
www.rcktpwrd.com
Old 29 Oct 2017, 03:23 pm
My02RedRide's Avatar
I was part of Team Shelby back in the day (mid to late 80's) . We used Mobil 1 5w-30 synthetic for the race car (G- body Daytona) trans with no issues. Will work just fine in a PT daily driver. My 02 manual trans I used Walmart Super Tech 5w-30 at 100,000 miles and actually shifts smoother now and cheaper. The extra I used in my John Deere engine 2000 13hp no issues.....
Overdrive likes this.
Old 29 Oct 2017, 04:46 pm
From AMSOIL website:
2009 CHRYSLER PT CRUISER 2.4L 4-cyl Engine Code [9]
LUBRICANTS & FLUIDS:
Manual Transmission,T350 (5-SPD)......AP4
All TEMPS......
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Old 29 Oct 2017, 06:03 pm
ATF+4 use that...
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 29 Oct 2017, 06:21 pm
Sinbad's Avatar
Thought the gearboxes needed ATF-4 because heavier oil made the syncro's wear out?
Is there no real difference in viscosity between the ATF and 5w-30?
Old 29 Oct 2017, 06:32 pm
OHHH YES THERE IS. ATF doesn't even list a weight because thats not what it is for.
ATF is basically a fluid with detergents in it. The whole point of ATF is to provide a liquid for pressure and detergents to clean stuff. Which in a Manual it doesn't even get used for pressure.
Engine Oil has multitudes of uses, Cooling, Lubrication, Multiweight features, ect.
They are not interchangeable. If they were, you would see a universal fluid you just put into one reservoir that powered everything.
Do not mix ATF with Engine Oil.
Old 30 Oct 2017, 12:29 am
Sinbad's Avatar
I wasn't going to - promise Just wondering why they say use ATF in the manual boxes - seems a bit counter-intuitive. But I read somewhere (cant remember where now ) that they use some kind of metal for the syncro's that acts badly with a heavier oil?
Gearbox bush set PTStuart Tech & Performance Forum 4 23 Feb 2015 11:01 am
Gearbox clunking stek2008 General PT Cruiser Discussions 4 07 Oct 2013 08:35 pm
Gearbox replacement swordfish Tech & Performance Forum 2 14 Oct 2010 07:22 pm
Gearbox noise?? siscor Tech & Performance Forum 6 03 Sep 2010 02:24 am
gearbox faults kenjenkins0123 Tech & Performance Forum 3 22 Mar 2009 08:21 am
