2008 PT Cruiser occasionally stops and shuts off.
  • 1 Post By chuzz
Old 13 Jun 2017, 08:55 pm
Default 2008 PT Cruiser occasionally stops and shuts off.
Hi there. I would first like to say that I am not car-savvy at all and I don't know very much, but I will try to be as detailed as I can be.
I own a 2008 PT Cruiser. Whenever I start it up, the car vibrates very hard to the point where you can see the dash vibrating and can feel it on the wheel. Sometimes it will be better to where it won't be vibrating the dash, but a lot of the time it is. It does not do this when I put the car in park, but when I am not moving in reverse or drive it will do this a majority of the time.
Sometimes the horn works and other times it does not. When I first bought the car, it did not work at all. I took it to a shop that said they got it working, but it seems like it only works fifty percent of the time that I press it.
The major problem, sometimes the car just completely shuts itself off. The steering wheel will become very hard to turn, braking is almost impossible if I do not use my e-brake, all the lights will turn off, stereo has no power, and I obviously cannot accelerate. It's just as if the car isn't on.
The car has 103k miles on it. It has been in an accident but it was rear-ended before I bought it. I do not have a warranty for it. I have taken it to a mechanic three separate times who has told me that he couldn't find anything wrong with it.
I'm at a loss and I really need a vehicle. If anyone out there can help me, I beg you. I don't know much about cars, but if you can help me I will try to provide you with any information I can.
Old 13 Jun 2017, 09:18 pm
rckstein's Avatar
Default Re: 2008 PT Cruiser occasionally stops and shuts off.
Welcome to the forum
The vibration when you put the vehicle into gear could be that the upper and lower torque struts are worn out and need to be replaced. If you took it to a competent mechanic, they should be able to tell from a simple inspection if the rubber inserts in the torque struts are torn.
As far as the horn, try pressing in several different spots around the horn pad.
Do you have information if the timing belt had been replaced on it before you bought it? That, and several other components, should be replaced at about 100,000 miles. It can be anywhere from $900-$1500 to have that work done.
Old 13 Jun 2017, 09:24 pm
Does your engine light come on? If so post the engine trouble codes?
Your ignition switch might not be working properly cutting off battery voltage to the engine.
Do you have many keys on your key ring?
Have you done a battery load test to verify your battery and battery charging system is working properly.
Old 14 Jun 2017, 06:55 am
First thing to do is take it to your local Advance, Autozone or O'Reilly and ask them to run the engine codes for you. Ask for a print out of those codes and post them here. Not knowing the history of the car, you may just need a good tune up and engine mounts, like rckstein said about the vibration. Steve has good info about the engine shutting down.
2006 PT Cruiser 2.4 Turbo stops running while driving...HELP! Shawneboismith General Turbo Discussions 2 21 Jun 2016 11:41 pm
2006 PT Cruiser 2.4 Turbo stops running while driving...HELP! Shawneboismith Welcome New PT Cruiser Members 0 21 Jun 2016 07:07 pm
2001 PT Cruiser starts then shuts off after a few seconds. jdell408 Tech & Performance Forum 4 22 Aug 2011 10:27 pm
2002 Pt Cruiser starts and then shuts off! please help vic001 General PT Cruiser Discussions 0 18 Apr 2011 12:35 pm
2001, auto, PT Cruiser, misfire, cuts out, stops tiredmom888 Tech & Performance Forum 1 30 Nov 2008 05:06 pm
