Neon Camshaft Swap - Cranks like no compression
Like Tree8Likes
Old 17 Jun 2017, 12:00 pm
Default Neon Camshaft Swap - Cranks like no compression
Jumped in and swapped Neon twin cams into my '05. Looked like a good option while refreshing head, but....
Won't start and cranks like there is little compression. Gassy smell out the tailpipe so thinking low compression or spark.
Head was checked, decked an complete valve job by trusted shop. No other changes other than, what I thought would be, a direct replace during reassembly. What did I miss?
Old 17 Jun 2017, 12:06 pm
Handy_Cruiser's Avatar
Default Re: Neon Camshaft Swap - Cranks like no compression
It's likely that one of both cams are not timed right. You may have installed one of your cams (likely intake) upside down. That is the reason why your motor has no compression. You likely need to install them with the #1cyl at TDC and both holes in the cams between cyl 1 and 2 straight up. On many setups like this, it will mean that the stock intake cam sprocket has to be upside down while aligning the marks.
Won't affect compression, but you do know that the cam sensor magnet has to be reclocked 180 degrees, right?
I predict this thread will soon develop into a heated discussion of how adding the Neon cams is of little or no benefit unless properly timed with variable cam sprockets. But for now, let's get that sucker timed right. If me, I'd go back with the PT cams.
Old 17 Jun 2017, 12:07 pm
Finding out what the engine compression is for every cylinder would help diagnose the problem.
Old 17 Jun 2017, 12:16 pm
Okay. Will check the cams for position. When I put the belt back on, I felt 4 good spots in my 2 spin check, thinking I was okay.
Reclocking cam position sensor? New to me. What do you mean?
Old 17 Jun 2017, 12:44 pm
Cam timing can ultimately be checked since with the #1cyl at TDC, both holes in the cams between cyl 1 and 2 should be straight up. So if the intake cam turns out to be upside down, you may have to install the timing belt with the intake cam sprocket upside down. And when you do that, the cam sensor magnet is now upside down. So you clip off the plastic dowel on the back of the timing magnet and tighten it up turned 180 degrees.
This stuff gets all confused on the internet because many folks used to install only the 2.0 exhaust cam which is good to go as is. Also, aftermarket camshafts often have extra dowel holes in the front to work on either 2.0 or 2.4 cam sprockets.
In summary, just make sure both holes in the cams between cyl 1 and 2 are straight up when #1 cyl is at TDC. And then if it has compression but doesn't start, rotate the cam magnet as described.
Also, there is no good reason to use the Neon cams. If you read though the SRT4 forum, you will find that they are only beneficial when properly advanced using variable timing sprockets. According to the SRT4 guys, you may lose power using them with stock cam sprockets.
Old 17 Jun 2017, 01:00 pm
rob302's Avatar
could you just lay the new cams next to the old cams to see if the lobes, dowel holes, etc, line up?
RCSnyder likes this.
Old 17 Jun 2017, 01:09 pm
Did that and cams looked identical. Going to compression test and dig from there.
Old 17 Jun 2017, 01:12 pm
There is a lot of hyp and myth then facts for the use of neon camshaft in the PT. My suggestion save your self all the trouble and reinstall you original cam set.
Butt Dyno reports are the most amazing part of Hot Rodding, everybody always claims "feeling" more power but almost never when actually tested on a real loive DYNO!
Originally Posted by Handy_Cruiser View Post
I predict this thread will soon develop into a heated discussion of how adding the Neon cams is of little or no benefit unless properly timed with variable cam sprockets. If me, I'd go back with the PT cams.
Then why even mention it?
You are not a control freak are you ...LOL naw!
Old 17 Jun 2017, 03:10 pm
Okay, so zero compression on all 4.
Lifted cover and spun to TDC. Exhaust cam's next move is set to open. Intake already open. Hmm. No good. Fresh cylinder fill to be pushed right out the exhaust does not sound like one of the four cycles I remember.
Intake clearly 180 off.
That answers the million dollar question.
Handy_Cruiser likes this.
Old 17 Jun 2017, 03:52 pm
rob302's Avatar
are you implying that he should buy cam gears, or that neons are not race cars?
i would listen to nitro..at least 50%...go with the PT intake cam. and try again.
do you really expect a random person to be able to clip off pegs, rotate something exactly 180, and secure it in such a way that it will be accurate for the next 100k miles? i just bought a $100 cam degreeing kit for my ford because i don't even trust the people that made my cam to be accurate to the degree.
Busted_PT likes this.
Intake camshaft and Exhaust camshaft dsent2 Tech & Performance Forum 7 08 Dec 2016 10:40 am
Neon R/T SRT-4 steering wheel swap _PTGT03 Interior Accessories Forum 3 23 Dec 2015 04:47 pm
Neon PT 5 speed trans swap?? drumrooster Tech & Performance Forum 3 30 Apr 2014 05:23 pm
Cruiser / Neon wheel swap ? ? ? eddielives Wheels, Tires, Suspension 2 05 Jun 2012 07:31 pm
