Blue o-ring that came with the cam seal?
Like Tree3Likes
  • 1 Post By Handy_Cruiser
  • 1 Post By rsrocket1
  • 1 Post By RVC
Old 17 Jun 2017, 02:57 pm
RVC RVC is offline
Default Blue o-ring that came with the cam seal?
What's it for? Is it for some other model than mine and therefore not needed in my '02 2.4? Can't find a place where it might fit behind the cam seal. I know this is probably another one of my dumb newb questions but I would like the engine to be right when I finally get it together.
Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 17 Jun 2017, 05:59 pm
Handy_Cruiser's Avatar
Default Re: Blue o-ring that came with the cam seal?
Is this the o-ring you are talking about? If so, it's for the cam sensor.
JoeX likes this.
Old 17 Jun 2017, 10:05 pm
RVC RVC is offline
I have the thin o-ring for the cam sensor. The one that came with the seal (Fel-Pro TCS 45961) is more round in cross section. As I think about it I figure the seal and o-ring are for other engines as well as mine (2.4L) and for our engines it's not needed. So I'll ignore it and hope for the best.
Thanks for the picture and your response.
RVC
Old 17 Jun 2017, 10:30 pm
RVC
I still believe that's a cam sensor o-ring. Fel-Pro has a long history of providing round o-rings where the originals had square cross-sections. I thought I had an extra one to make sure, but I must have used it.
Old 18 Jun 2017, 10:54 am
rsrocket1's Avatar
The black seal is seal that goes behind the camshaft sprocket when you do a timing belt change, but I'm sure you already know that.
This is what I saw in the Autozone description:
Package Contents: Camshaft Front Seal, Camshaft Position Sensor Seal
Handy_Cruiser likes this.
Old 18 Jun 2017, 11:35 am
RVC RVC is offline
OK, so that settles it. Thanks!
RVC
2001 Water Pump - O-Ring Won't Seal tdf Tech & Performance Forum 4 22 Jan 2014 12:44 am
Reverse ring ring turbomangt General PT Cruiser Discussions 12 06 Apr 2007 11:35 am
Bad Ring turbokidd Turbo Performance 2 17 Feb 2007 03:35 pm
WTB~4 ga. ring terminals OurPTGT Classifieds: Want To Buy 5 13 Feb 2005 04:24 pm
