5-speed
Like Tree2Likes
  • 2 Post By linkinparker445
Old 17 Jun 2017, 11:05 pm
Default 5-speed
5th isn't tall enough in my 01. Can I change it, or should I get a 6-speed?
Old 17 Jun 2017, 11:14 pm
Handy_Cruiser's Avatar
Default Re: 5-speed
You have a 2001 PT, right?
If by not being "tall enough" you mean 5th gear doesn't seem high enough, then the answer is that changing it is not really feasible. While it may be possible to install another type of manual transmission with lots of time and money, the cost would be more that a 2001 is worth.
Also, I can't see how you could be red-lining your PT while in 5th gear. It just doesn't have the power to get there unless you are speeding down a very sleep hill. So what exactly is your issue with what you have?
Old 17 Jun 2017, 11:42 pm
Carnut's Avatar
Default Re: 5-speed
Installing larger diameter tires will make 5th gear 'taller'.
George H. McDowell
Wichita, Kansas
mailto:carnut@carnut.com
http://www.carnut.com/
FB https://www.facebook.com/george.c.mcdowell
My 2005 PT Cruiser GT Convertible Project
Old 18 Jun 2017, 12:13 am
rob302's Avatar
Default Re: 5-speed
Someone recently said the 2.2 diesel trans fits and had a taller 5th
Old 18 Jun 2017, 10:45 am
rcktpwrd's Avatar
Default Re: 5-speed
In '03 I think it was Chrysler changed the final drive ratio in the n/a manual transmission. This lowered the rpm at highway speed...
Joel
www.rcktpwrd.com
Old 18 Jun 2017, 08:09 pm
Default Re: 5-speed
All NA PTs with the T350 have 3.94 final drive. The 2001 has .81 5th, 2002 and later cars have .72 5th, so you can swap in a new model year transmission to lower revs on the highway.
2004 Touring Turbo Lite, Hahn 20g turbo, ATX ->T350 5-speed swap, mtx stage 1 pcm, DiabloSport InTune, rear sway bar, Wilwood big front brakes, rear disc brake conversion, Drop Zone springs, SRT4 dual exhaust
Old 22 Jun 2017, 03:37 pm
TurboDucky's Avatar
Default Re: 5-speed
Yep, my '01 had the lower 5th gear and it drove me crazy at highway speeds. Over 3k rpms going 70+. Swapped in an '05 trans and it's a bit happier now.
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Tags
5-speed, 6-speed
Locating Radiator Fan relays High Speed and Low Speed CashReject Tech & Performance Forum 14 06 May 2017 12:12 am
Need. More. Speed. Now FanDroid General Turbo Discussions 3 25 Nov 2011 09:10 pm
Top Speed ? TripleJackInGA General Turbo Discussions 17 23 Jun 2010 10:24 am
Is the 4 Speed A/S realy a six speed? Ian-PT-GT General Turbo Discussions 11 16 Apr 2004 10:19 pm
top speed skeeter1620 General Turbo Discussions 10 11 Jan 2004 03:20 pm
