Help
Like Tree2Likes
  • 1 Post By ptcruisersteve
  • 1 Post By CREWZIN
Old 19 Jun 2017, 11:58 am
Default Help
I hooked up a new battery in my 06 pt cruiser backwards and now my ac compressor dosent work and my radio dosent work can somebody help me please
Old 19 Jun 2017, 12:09 pm
VsandFords's Avatar
Default Re: Help
Welcome to the forum from Texas.
Please go to the new members section and introduce yourself.
There is already a thread with the same scenario, a battery hooked up backwards. You might want to check it out.
Old 19 Jun 2017, 05:16 pm
Default Re: Help
I would suggest keeping in mind that the PCM output to the TIPM needs to be checked before looking at or repairing the TIPM. The PCM sends signals to the TIPM inputs on A/C clutch control.
On the TIPM there is a possibility that the circuit board or the components on the circuit board may need to be repaired. The TIPM is not designed to have the battery hooked up backwards and might have some internal components burnt or open contacts. Some members have suggested resetting the TIPM but I have not heard from anyone if that helps on this issue.
Handy_Cruiser likes this.
Old 19 Jun 2017, 05:25 pm
Default Re: Help
....OR you could have blown a fuse or two especially the IOD. Have you checked them ?
Old 20 Jun 2017, 12:09 pm
Default Re: Help
