Car wont start.
Like Tree2Likes
  • 1 Post By ptcruisersteve
  • 1 Post By JoeCruiser
Old 19 Jun 2017, 01:52 pm
Smile Car wont start.
Hello Friends...
I have a 2004 PT Cruiser where the car starts for 60 seconds and then it will die. Crank, Crank & Crank but wont fire back up until I disconnect the battery for 1-2 minn and then re-connect and it will fire back up for 60 seconds and die again. My question is this, could this be a faulty Fuel Pump or most likely a Crankshaft Sensor?
Thank you.
Old 19 Jun 2017, 02:20 pm
JonN's Avatar
Default Re: Car wont start.
Is the check engine light on? Have you used an OBD2 scan tool to check for any check engine codes? It's hard to say what it could be without more information.
2016 Jeep Patriot Sport 2.4L 6 speed auto 97k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 19 Jun 2017, 04:57 pm
I would suggest a battery load test. Make sure your battery voltage is not dropping after you start the engine.
JoeCruiser likes this.
Old 19 Jun 2017, 07:15 pm
The first code was P0688 but could not find that number when I looked it up. Could this be a stored code? or could it be an ECM issue?
Old 19 Jun 2017, 07:26 pm
I found this online on several websites for P0688:
"defective ECM relay or faulty wiring."
Series 3 Dream Cruiser
Old 19 Jun 2017, 07:29 pm
Also as ptcruisersteve suggested weak battery; Low voltage while cranking
Old 19 Jun 2017, 10:58 pm
Are you getting engine trouble code P0688?
No start. The Powertrain Control Module (PCM) will not ground the Automatic Shut-Down Relay (ASD) relay. Code P0688 is stored....
2006 Chrysler PT Cruiser 2.4L, Vin B
Test Details... Confirmed Fix Details...
Tests/Procedures: 1. Ground the control wire from the ASD relay at the Powertrain Control Module (PCM) connector. Also try test the ASD relay operation with the ATM tests found in a compatible scan tool.
17 Confirmed fixes
Automatic Shutdown (ASD) Relay
Automatic Shutdown (ASD) Relay Wiring
Crankshaft Position (CKP) Sensor
8 - Powertrain Control Module (PCM)
2 - Fuse #19
1 - Fuse #32
1 - Totally Integrated Power Module (TIPM)
1 - Fuse #18, Fuse Box Terminals
1 - Crankshaft Position (CKP) Sensor Connector, Ignition Coil Assembly Connector
1 - Automatic Shutdown (ASD) Relay
1 - Powertrain Control Module (PCM) Wiring
I still suggest checking the battery and battery charging system first.
Old 20 Jun 2017, 07:28 am
Sounds to me like you've got the wrong key. Are you using a chipped key or a "valet" key? Yeah, it could be that simple. If your PT uses a chipped key and you're using a key you got made somewhere, that's normal. SKIM is not reading the chip, assumes the car is being stolen and shuts it down.
Old 20 Jun 2017, 08:50 am
_PTGT03's Avatar
drain the tank and add new gas
Pt wont start wdlee General PT Cruiser Discussions 22 23 Nov 2014 07:36 pm
PT Wont Start stan General PT Cruiser Discussions 4 07 Jan 2014 08:21 pm
car wont start s_m_49319 General PT Cruiser Discussions 2 25 Dec 2013 12:19 pm
04 pt wont start penstar66 General PT Cruiser Discussions 6 01 Sep 2010 02:27 am
07 TE PT wont start PLEASE HELP!!!!! Norma Tech & Performance Forum 10 08 Dec 2008 08:58 pm
