Help please. Pt dies after 10 seconds
Like Tree18Likes
Old 26 Jun 2017, 12:49 am
Exclamation Help please. Pt dies after 10 seconds
Hello.
So back story.
Went to wash the car and coming out of the wash it stalls.
Tried starting and it fires up then dies.
So I was thinking fuel pump.
After replacing pump it starts like a new car and idles sir 10s then starts to sputter them dies. Any ideas??
Code is p0171
What I've done so far.
I have Cleaned the tank,line,injectors,fuel rail
Tested the injectors and all spitting very well.
Full throttle body clean as well
Gasket check and they are still very good.
Checked for about 3 hrs to see if I can locate a leak and all is good
I did sensor swap with my wife's pt cruiser as well to rule out any annoying sensor issues.
I'm at a loss at this point.
I can feel the pump working and I made sure there was fuel coming out the front of the car to rule out and kinks in the line and what not.
I've reset the ecu a number of times but keep getting this code (p0171(
Now, I've heard there was a relay intergraded in the fuse box and I've noticed my turning signal don't work or my cruse control and my horn don't work but it worked when locking. Now it don't work.
Can it be my fuse box just took a giant dump??
Also when it starts I push the gas but all it does is bogs down and dies
Old 26 Jun 2017, 01:51 am
Default Re: Help please. Pt dies after 10 seconds
This code can be caused by low fuel pressure, bad oxygen sensors, vacuum or air leak, or incorrect valve timing.
I would suggest checking the fuel pressure. Make sure you are getting 58 +/- 5 PSI.
By the way welcome to the forum.
Old 26 Jun 2017, 11:54 am
ROFL ! ! ! Okay I can't believe I get to say this but... "Don't panic, step back guys I got this"!!
First of all, Hi Boomcruiser06 and welcome to the forum! I think you will find that there is an invaluable wealth of information here provided by a bunch of great peeps that are eager to help. While we roll up our sleeves and prepare to dive in, why don't you head over to the "Welcome New PT Cruiser Members" section and tell us a little about yourself.
As far as the issues you are having with your Cruiser, it SCREAMS TIPM to me. Do you have any "pick and pull" salvage yards nearby? So far from what I've learned, you should be able to use a TIPM from a 06 to an 09. While there is a risk in salvage parts I replaced mine for 30 bucks same day as apposed to spending between two and five hundred and waiting Dog only knows how long for shipping. It's a gamble but with really good odds.
Old 26 Jun 2017, 12:02 pm
rckstein's Avatar
As you stated, getting a used electrical part would be a gamble, especially something as important as the TIPM. When I was at several area yards a few weeks ago, many of the vehicles don't have hoods, which means that the TIPM would have been exposed to all of the weather elements beating down on it, for however long that vehicle has been in the yard. Also, of all the PT's in the yards that I was in, there was only one Gen2, so not a lot of selection to get one from.
Also, there have been reports of problems with even the replacement TIPM's as I don't think there is such a thing as a brand new one, but all of them appear to be remanufactured.
Hopefully you got your PT fixed with the used one you found.
Old 26 Jun 2017, 12:22 pm
I must have gotten lucky here, they had an 06 and an 08 sitting there almost intact. So far so good, I just went out and started the car to make sure. We'll see how she acts when I go out for the emissions test this afternoon.
Handy_Cruiser likes this.
Old 26 Jun 2017, 12:45 pm
Handy_Cruiser's Avatar
EDITED
Hey, sounds like you may have gotten it fixed before I finished posting!
Old 26 Jun 2017, 12:48 pm
rckstein's Avatar
I just called a local dealership and the part number for a replacement TIPM for my PT (the same as yours) is R6049719AR with a list price of $745 with exchange core charge is $125 and per the parts person, it must be programmed to the vehicle. Also, the ones from Chrysler are remanufactured.
There are cheaper ones available, for instance on RockAuto and watching the short video for the Dorman one, it's supposed to be plug and play replacement.
My PT didn't originally come equipped with driving lights, but I had the kit added by the dealership before I took possession of the vehicle. So that option had to be programmed into the vehicle. I just don't know if it gets programmed into the PCM or TIPM, and if I replace the TIPM, will I have to take it back to a dealership to have it reprogrammed? I guess I would find pretty quick because if the driving lights don't work again after replacement of the TIPM, then it would require a visit to the dealership for programming. But according to the short video on the RockAuto website under the Dorman TIPM, you program it using the vehicle key and the replacement TIPM learns the VIN.
More Information for DORMAN 599909
Old 26 Jun 2017, 01:13 pm
Originally Posted by Boomcruiser06 View Post
Hello.
So back story.
Code is p0171
P0171 - Fuel System 1/1 Lean
Possible causes:
1. Restricted fuel supply line
2. Fuel pump inlet strainer plugged
3. Fuel pump module
4. O2 Signal circuit
5. O2 Return circuit
6. O2 Sensor heater operation
7. O2 Sensor
8. Map sensor operation
9. ECT sensor operation
10. Engine mechanical problem
11. Fuel filter/pressure regulator
12. PCM
Before looking at the TIPM as a possible cause we need to look at why the P0171 is being triggered. You indicated you are getting fuel but what is the fuel pressure? It should be 58 +/- 5 PSI. Many members could have saved funds and time if they had checked the fuel pressure before looking at other possibilities. If a component is shorting out it can affect the TIPM so we need to look at all the circuits that might affect the outcome.
Old 26 Jun 2017, 01:54 pm
When the OP posted that trading out the salvage TIPM fixed his issues, I was in the middle of a long dissertation where I would have tried drying out the TIPM and other connections.
But what I liked about his solution (if it actually works) is that the programming of the TIPM is not for the SKIM (like a PCM needs), but simply to work in that model of vehicle. And if that's the case, using the TIPM out of another similar model PT will likely work as is. We know that the 2nd Gen instrument cluster works this way so there's good reason to believe the TIPM does too. The programming procedure is not required for a salvage cluster from a like model. And that Dorman video may be refereeing to a different TIPM on the "faster" CANbus on other cars, and only generally applies to PT's.
But I guess we will know if and when the OP returns to report how his transplanted TIMP is doing. It's cool stuff either way.
rckstein likes this.
Old 26 Jun 2017, 03:25 pm
Possible causes:
3. Fuel pump module
7. O2 Sensor
12. PCM
I'm assuming the pump is what must of triggered something. I put the old pump back in and the car won't even start. But when I put the new one in it starts and idles like new then 10 seconds later or so it sputters and dies.
Starts, runs for a few seconds, then dies Cmoore Tech & Performance Forum 5 28 Feb 2016 08:59 am
Fan keeps running for several seconds dm4 Tech & Performance Forum 4 13 Nov 2015 02:30 pm
Air Conditioner pressure from 0 to 45 in 2 seconds PlasticArdvark Tech & Performance Forum 3 22 Jul 2013 10:48 am
