Backfire / popping
Like Tree3Likes
Old 28 Jun 2017, 03:29 pm
Default Backfire / popping
I just cant get a break with this damn thing. It has been 2 years since it ran, every time I think its done, it isn't. I have replaced almost everything on the car.
I can drive the car around with no problem as long as I don't mash the throttle. It runs and idles fine but as soon as I try get on it starts popping and back firing. What good is having a turbo if you cant beat on it periodically. I have done my best to check for vacuum leaks and to the best of my knowledge, there isn't any.
Any suggestions.
2003 PT Cruiser GT - Hand Me Down from Dear Old Dad / Mods: Lowered - Gauges (Boost, Oil Pressure, Volt, EGT, A/F
Old 28 Jun 2017, 03:37 pm
_PTGT03's Avatar
Default Re: Backfire / popping
Have you tried emptying out the tank of old gas and installing fresh premium grade fuel ?
Old 28 Jun 2017, 04:32 pm
To make sure we are not in a guessing game please post what you have done to the Pt Cruiser to solve this problem so far?
Old 29 Jun 2017, 01:54 pm
I made sure to syphon as much old gas and add new.
Everything has been replaced and the timing is correct.
Old 29 Jun 2017, 02:41 pm
Including the turbo?
Old 29 Jun 2017, 09:30 pm
_PTGT03's Avatar
is the backfire through the intake or exhaust side
Old 29 Jun 2017, 10:02 pm
Yes..........Including the turbo.
There are no CEL.
Old 29 Jun 2017, 11:28 pm
I would suggest checking the fuel pressure that should be 58 +/-5 PSI.
If the fuel pressure is greater than 48 PSI when accelerating then I would suggest you check your CAT. Make sure it is not clogging up.
What brand and type spark plugs did you put in the PT Cruiser?
What gap did you set the spark plugs at?
What brand spark plug wires did you put in it?
Old 30 Jun 2017, 02:57 pm
_PTGT03's Avatar
Perhaps the backfiring has something to do with a lean fuel ratio. The fuel pressure regulator is integrated into the fuel sending module inside the gas tank. Did you ever do a pressure or volume test like suggested above ?
Old 30 Jun 2017, 03:06 pm
rob302's Avatar
i would suggest hooking up a vacuum gauge to see what the needle does...
followed by a compression check.
i had a weird issue. slow car, backfire. it was more or less an intake valve failing to close. here: here's a new one
ptcruisersteve and chuzz like this.
OFF IDLE MISS WITH OCCASIONAL BACKFIRE Jdhaulr1 General Turbo Discussions 46 29 Sep 2016 11:41 pm
rough running, backfire bsides45 Tech & Performance Forum 10 27 Feb 2013 05:17 pm
Backfire / air conditioning Choctique General PT Cruiser Discussions 3 26 Nov 2012 10:21 pm
02 pt cruiser backfire vanhalen7174 Tech & Performance Forum 1 15 Mar 2010 07:53 pm
Pop and backfire,2500-3000 RPM puptote Stage Turbo Kits 15 25 May 2007 06:58 am
