Motor won't crank
Like Tree2Likes
  • 1 Post By _PTGT03
  • 1 Post By _PTGT03
Old 29 Jun 2017, 09:16 pm
Default Motor won't crank
Newbie looking for advice. I just got a 2007 pt base convertible with 2.4 auto. I received the car non running and don't have a lot of info on it. The previous owner told me he had a new key cut for it but never got it to crank(which is how I acquired the car cheaply) the battery and cables looked horrid so I pulled the batt and hooked my suburban up to it with jumper cables. I got the dash cluster to light up and got a "no bus" message and a constantly flashing security light. I tried the key dance and couldn't get any codes to come up. The power windows do not work but I can get gauge light on, radio lights up, and the power top will function. I know the ecm goes bad in these pretty regularly. I'm wondering where to start. Is the skim feature holding me back, is the key programmed correctly. I'm hoping to borrow a scan tool tomorrow and see if I can find some codes to give me more insight but I will take all the advice I can, thank you in advance!
Old 29 Jun 2017, 09:45 pm
_PTGT03's Avatar
Default Re: Motor won't crank
i suggest to get alldata for your model. use the scantool and troubleshoot down to a component or circuit level, and eliminate possible causes.
woodbn likes this.
Old 30 Jun 2017, 06:40 am
If the key you got with the car isn't an original key, then that's most likely a big part of the problem. Walmart key that is more of a valet key. Repeatedly trying to start it with that probably activated the security system and now you're locked out.
Old 30 Jun 2017, 07:23 am
Is that a dealer issue to have the key reprogrammed or can a locksmith do that? Is there anyway to bypass the SKIM feature?
Old 30 Jun 2017, 02:54 pm
_PTGT03's Avatar
Yes, however it has to be de-programmed from the computer. The computer will have to sent in for special work. It's similar to how the porsche systems have their security systems removed for racing.
woodbn likes this.
PT Cruiser no crank or sometimes crank scenario bgkidz General PT Cruiser Discussions 4 23 Apr 2017 06:25 pm
@002 will crank but will not run jrywb329 General PT Cruiser Discussions 0 01 Jun 2014 10:47 am
Looking To Replace Either Fan Motor Or Fix Motor If Possible - Anybody BTDTGTBT... scoleman69 Tech & Performance Forum 8 22 Dec 2013 05:33 pm
Won't crank sometimes! RodF763 Tech & Performance Forum 8 09 Sep 2010 12:31 pm
