Stripped oil drain, oil pan question
Like Tree4Likes
  • 1 Post By VsandFords
  • 3 Post By Faulkster
Old 30 Jun 2017, 07:20 pm
Default Stripped oil drain, oil pan question
So the idiots at the oil change place stripped my oil drain plug and put in a self-tapping one.
Question is will an oil pan from an '03 fit my '06?
I need to know for tomorrow morning.
Chris Faulk
2006 Limited PT Cruiser
88,000 miles
Old 30 Jun 2017, 08:02 pm
Default Re: Stripped oil drain, oil pan question
I went to the Auto Zone site and looked up OIL PAN (Dorman #264-241) and put in 2003 PT and it fit and changed the car to 2006 PT and it also fit that year so you should be good to go.
You can try it yourself at this site....
Best Oil Pan Parts for Cars, Trucks & SUVs
Old 30 Jun 2017, 08:41 pm
Thank you sir!
I'm likely going to have to do a helicoil.
Chris Faulk
88,000 miles
Old 01 Jul 2017, 06:40 am
What's wrong with having the self-tapping one? Does it leak? Just another example of why you should do your own oil changes, if it's allowed where you live.
Old 01 Jul 2017, 07:53 am
There's already a self-tapping oversized bolt in there and it's stripped. Besides, you're more likely to crack the pan than fix the stripped threads.
Chris Faulk
88,000 miles
Old 01 Jul 2017, 07:59 am
rckstein's Avatar
Here's a procedure of using JB Weld to install a piggy back drain plug:
https://axleaddict.com/auto-repair/O...ug-Easy-Repair
Might be worth a try unless you really want to replace the pan. IMO, the shop that stripped the plug should be covering the replacement. I wouldn't want them doing the repair, but they should reimburse you to have the pan replaced at a shop of your choice.
Old 01 Jul 2017, 08:02 am
VsandFords's Avatar
Dorman makes a oversize piggy back drain plug. Like a plug in a plug. It is the simple fix. There is nothing wrong with using a Helicoil, although the cost of the kit may be close to the price of a used replacement pan.
rob302 likes this.
Old 01 Jul 2017, 09:03 am
My idea was similar, but that's a pretty ingenious solution.
The M16 in there now is stripped so I'm limited on solutions.
Thanks guys!
Chris Faulk
88,000 miles
Old 10 Jul 2017, 08:25 am
The piggyback oil drain plug has been holding and seems to be a viable fix!
Thanks guys!
Chris Faulk
88,000 miles
Battery drain question yourlefthand Tech & Performance Forum 13 16 Jul 2014 12:21 pm
I stripped my thermostat housing! OneLeggedPuke General PT Cruiser Discussions 8 23 Jan 2014 12:07 pm
Intake bolt stripped lostinoregon Tech & Performance Forum 8 16 Dec 2012 01:39 am
Stripped thread Stempy Tech & Performance Forum 3 18 Nov 2012 01:05 pm
Battery Drain Question PTFlorida Tech & Performance Forum 14 18 Nov 2012 08:46 am
