Fuel pump pressure
  • 1 Post By GtPt05
Old 01 Jul 2017, 05:01 am
Default Fuel pump pressure
Ok. On the 2004 and up there is no Schrader valve. Maybe Nitro can advise since he is a professional. Is there an adapter or do you cut the line and splice in a T fitting?
Old 01 Jul 2017, 05:48 am
rob302's Avatar
Default Re: Fuel pump pressure
I'll look at the condition of the rail on mine tomorrow when I'm off work. If it looks decent, I'll send it to you free. Upper intake is of so it should only be a 5 minutes project on my end.
Or nitro may have a better idea?
Old 01 Jul 2017, 06:06 am
If you just want to check the pressure, there are lots of kits out there that have fittings to allow you to run the gauge in-line while running the vehicle. If you are looking to permanently install a gauge, you can install an older style rail with the schrader valve. That's what I did. Works great, and avoids unnecessary fuel line splices.
NitroPT likes this.
Old 03 Jul 2017, 04:41 am
Thanks. I was amazed that there was no provision. What were they thinking by removing it? Only makes for potential problems having to splice a fitting in I would think.
Old 03 Jul 2017, 05:34 am
My guess is that the rail without the schrader valve was probably cheaper, and the dealer techs would have the adapters needed to connect a gauge in-line at the factory connectors, so they opted to save where they could. Nice for them, not so nice for us!
If you have a gauge that doesn't have the adapters, you could snag a fuel line from a salvage yard or buy online, use the end that connects at the firewall, cut the line and attach a hose for the gauge. You would only be able to test initial key-on pressure, but it could be helpful...?
Old 03 Jul 2017, 07:46 am
rckstein's Avatar
In the Service Manual, this is the special tool mentioned to check fuel pressure:
Miller #6539
Miller / Mopar Tools 6539 5/16" Fuel Pressure Test Adapter
Old 03 Jul 2017, 09:14 am
Miller #6539
Aha! It figures
Clogged fuel filter, low fuel pressure or what? Gilgrin Tech & Performance Forum 8 01 Jun 2016 04:57 am
New fuel pump, but now no fuel to front? bundixlake Tech & Performance Forum 14 21 Mar 2014 09:41 pm
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
AC pump high pressure switch joereott21 Tech & Performance Forum 3 07 Oct 2011 08:19 am
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
