Change Timing Belt Without AC Hose Disconnection
Like Tree2Likes
  • 2 Post By DBKPT
Old 02 Jul 2017, 02:51 pm
Default Change Timing Belt Without AC Hose Disconnection
1. Put jacks under engine oil pan and transmission.
2. Remove transmission mount from left inner fender.
3. Remove bolt from center engine mount on right inner fender.
4. Lower transmission just enough to clear left inner fender.
5. Engine can now be moved left about 1 and a half inches away from right inner fender.
6. Upper dog bone mount can be removed without unhooking AC hoses or removing bracket from shock tower.
7 Jack up engine and lower transmission to make removing center mount plate much easier.
8.Install timing belt, water pump, idler, and tensioner in the usual way.
9:Install center mount, timing cover, and all the belts before moving he engine back into position.
Carnut and JDK52 like this.
Tags
ac hose, timing belt
TIMING BELT CHANGE.....thanks to all. georgespt Tech & Performance Forum 1 04 Aug 2015 08:12 am
After timing belt change veracruise Tech & Performance Forum 5 03 Dec 2010 07:17 pm
Timing belt change - is this possible? nx13688 Tech & Performance Forum 1 14 Oct 2010 06:50 pm
timing belt change? Ginz General PT Cruiser Discussions 15 16 Sep 2010 09:16 pm
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
