Auto trans fluid change possible pan drain bolt issue?
Like Tree6Likes
  • 1 Post By JDK52
  • 2 Post By NitroPT
  • 1 Post By JDK52
  • 1 Post By NitroPT
  • 1 Post By NitroPT
Old 11 Jul 2017, 08:50 pm
Default Auto trans fluid change possible pan drain bolt issue?
Bought my first pt recently going through the car servicing the everything in my spare time. Got to a video of a guy changing auto trans fluid...gasket... filter etc. He ran into an issue with the pan not clearing the drain plug nut on the inside of the pan while he tried to re-install it against the trans and bolt it up was binding on the filter. He said he needed to buy a new pan but didn't say which one does anyone happen to know of this? If so can anyone also provide a part number for that replacement pan? I have an 02 no turbo. Thanks
Old 11 Jul 2017, 09:31 pm
JDK52's Avatar
Default Re: Auto trans fluid change possible pan drain bolt issue?
Sounds like you need a new video, not a new transmission pan.
Busted_PT likes this.
Old 11 Jul 2017, 10:01 pm
Dorman Products - 265-801 for 41TE PT Cruiser
Application: Transmission model A604, 41TE or 41AE (14 bolt fluid pan)
rsrocket1 and Ptcroozer like this.
Old 12 Jul 2017, 03:36 am
Thank you for the helpful reply and sorry if my questions seem "knobby" I'm still trying to get to know these cars. So is there actually an issue with the factory drain bolt hitting the filter or was that guy blowing smoke? Looked up that part number thanks.
Old 12 Jul 2017, 03:59 am
Ah sorry... I see the drain plug on the pan you suggested has the drain plug relocated to the bottom of the pan. PERFECT thanks!
Old 12 Jul 2017, 06:03 am
JDK52's Avatar
Ptcroozer,
The original transmission pan has no drain plug, therefore no problem with a drain plug hitting the filter! (Hence my original short response)
The after-market pan with a drain plug does seem a consideration for ease of future service. Having the transmission fluid out before removing the pan is bound to be less messy.
The biggest effort in this job is cleaning the silicone sealer used as the gasket.
If this thread goes on any longer someone will surely be along to remind you to only use ATF+4 fluid.....
Ptcroozer likes this.
Old 12 Jul 2017, 08:44 am
I race often and use Marvel Mystery Oil when when doing my personal filter fluid service. Many that do suggest a "feeling" of improve shift quality.
Old 12 Jul 2017, 09:41 am
Originally Posted by JDK52 View Post
Ptcroozer,
The video I watched must have had an aftermarket pan then as the drain was on the side of the pan and the inside nut kept hitting to filter during install. Sure looks like that RTV takes a bit of time to remove. The car is in the yard in the meantime im driving my rx8 so it's nice not to be in a rush I can let it cure overnight before refill. Thanks for the advice for many years I've been an AMSOIL guy then lots of searching online for these cars always says +4 ATF not even sure if AMSOIL makes that haven't had a chance to browse.
Old 12 Jul 2017, 09:45 am
Hmmm... that's interesting mine bumps shifts up and down in second another thing I'm gonna address at some point soon don't need the car on the road until October. I wonder if the improved shift feeling is a reality ill check it out when I get more time.
Ton a need to figure out that BUMP shifting does it mostly when cold but winters where I live can hit -50 rare as that is but it's always cold 6 months of the year! lol you typically get lots of drag on any trans until you've been driving for a while and that translate to premature service life. Although synthetics make a massive difference here in winter.
Old 12 Jul 2017, 02:33 pm
Not sure where you live but I get all the extreme here where I live winter months in the low 20f's and summer can get to 114f+.
If you have shifting problems one of suspect parts is the SOLENOID MODULE.
TRANS FLUID CHANGE ALBERT Feedback and Support 6 31 Aug 2012 10:16 pm
wtb auto trans pan w/drain plug OurPTGT General PT Cruiser Discussions 2 28 Nov 2011 07:02 pm
Changing Auto Trans Fluid mjb457 Tech & Performance Forum 5 19 Mar 2011 02:48 pm
Fluid for auto trans oil cooler nighthawk417 General PT Cruiser Discussions 2 01 Jan 2011 08:45 pm
ATF+4 auto trans fluid finally available MX-5 Tech & Performance Forum 3 04 Sep 2003 01:20 am
