Overflow Volume
Like Tree2Likes
  • 2 Post By GtPt05
Old 16 Jul 2017, 05:50 pm
Default Overflow Volume
I'm planning to replace the factory overflow with an aftermarket. I've searched some to locate details on the factory overflow to determine volume, with no success. How much does the factory overflow hold? Not full, but within the hot & cold designated volume. Thanks!
**2005 PT Cruiser Touring Convertible Turbo - 20x8" Milani Wheels 245/35 & 225/30, air ride & more.
Build Thread: http://www.ptcruiserlinks.com/forum/...ser-turbo.html
**2008 PT Cruiser
**2007 Chevy HHR LS - Transition to LT - 18" Solstice Wheels 235/45 & 225/45
Old 16 Jul 2017, 08:29 pm
Default Re: Overflow Volume
Mark yours cold, and hot. If it moves much, manually fill it to the high line, then use a turkey baster (or whatever) to extract down to the low line, and measure the amount you removed. Add some for extreme conditions. That should represent the volume you need. I'm personally not a big fan of the overflow tank... It's a massive space thief in any engine bay. Unless your having a cooling issue, I think a small vented canister would suffice, for the purpose of expansion and vacuum ventilation, with an occasional purge of a small amount of coolant. I'll be mounting a very small version somewhere completely out of the way. I'd prefer to eliminate it all together.
Nvizn and chuzz like this.
Old 16 Jul 2017, 09:10 pm
I thought mine had a hole, until I removed it. Turns out it's the turbo coolant line..... =/
**2008 PT Cruiser
Old 17 Jul 2017, 07:27 am
^^^^ Bummer, man. That'll cost more than another overflow jug. And it's more of a pain to change out too.
Amp turns off when I turn up the volume. darknecrotic Sound and Security Forum 9 01 Oct 2012 05:49 pm
No Volume on Radio lrball Sound and Security Forum 3 29 Apr 2011 02:10 am
volume issue when playing a mp3? red06limited Sound and Security Forum 0 25 Feb 2011 04:50 pm
Radio turns its volume down by itself? AshtonPJ General PT Cruiser Discussions 6 23 Dec 2008 03:20 pm
More volume out of stock radio? Capt Kidd Sound and Security Forum 3 13 Jul 2004 05:06 pm
