TO MUCH OIL ON A/C SYSTEM
Like Tree10Likes
  • 1 Post By sobrements
  • 1 Post By NitroPT
  • 1 Post By NitroPT
  • 1 Post By rob302
  • 2 Post By Handy_Cruiser
Old 18 Jul 2017, 12:55 pm
Angry TO MUCH OIL ON A/C SYSTEM
Hi i have a pt cruiser 2004 and i have a problem whit my A/C on refiling it i add a can of r134a plus and it add oïl inthe can about 3 ounces, the system who was already containing the good amount of oïl now i am pretty shure i have about 3 onces of oïl exeeding and it make my system running on hi pressure eaven if i had changed the line whit the filter in !
How can i get the excess oïl from it any suggestions ?
i was thinking of removing the high pressure blow plug and start the engine by remote control !
any idea !
thanks
Francois
Gkon likes this.
Old 18 Jul 2017, 01:05 pm
Default Re: TO MUTCH OIL ON A/C SYSTEM
If you think you have a refrigerant issue regarding oil % to Freon I HIGHLY recommend that you take it to a shop that advertising performing AC repairs.
They will completely evac your system and determine if it warrants replacing or simply reinstalling to proper levels and pressure. Without ALL the proper AC service equipment this can not successfully perform on a DIY level.
If you are asking the questions , the first response then I can tell you for your own safety and to prevent damage to your AC system DONT ATTEMPT a correction yourself.
Gkon likes this.
Old 18 Jul 2017, 01:07 pm
Welcome to the forum
You might want to start a thread and introduce yourself. Check out the Forum:
Welcome New PT Cruiser Members - PT Cruiser Forum
specifically information for NEW members :
WELCOME and Forum Rules
We encourage all new members to say hello and introduce yourself to the rest of the community by starting a post in the Welcome New PT Owners thread at the top half of the forum.
Gkon likes this.
Old 18 Jul 2017, 01:25 pm
hi nitro pt !
I am a mechanics class 2 and i have all Tools needed for the job but never remove oïl from a/c system !
thats why i ask !
Francois
Gkon likes this.
Old 18 Jul 2017, 01:35 pm
rob302's Avatar
the only way i have removed oil from a compressor was by accident. i removed the compressor and turned it upside down. you could remove it from the car, empty it, and add correct amount of oil. IMO there is no way to accurately measure unless you start from empty.
i do all my own work, but i will still take my car to a shop for AC service. i want my AC to be COLD and i know they can get it colder than i can, since i can't properly evacuate the system and remove moisture from the lines. if you can't properly do that, you do not have the right tools.
Gkon likes this.
Old 18 Jul 2017, 01:40 pm
thats what i dont want to do remove avain the compressor thanks for the adviced !
Gkon likes this.
Old 18 Jul 2017, 03:49 pm
Handy_Cruiser's Avatar
Welcome to the forum.
If me, I would first take the PT to a shop and ask how much it would cost to have my AC system discharged, drained of oil, and then refilled. There's a chance a shop can do this cheaper than you can do it at home.
If trying to do this at home, the problem is that there is usually no good way to discharge the system at home without letting all the Freon off into the air. While I'm sure we've all done this many times before we knew better, it now become a moral questions we each have to answer for ourselves.
Once the system is discharged (however it's done), I'd try removing the high pressure switch on the back of the compressor. These are know to leak oil when the o-ring goes bad. So it's possible I could get 3 oz. of oil out of it that way. Of course, I would be guessing how much oil I lost during the discharge too. But if successful, I'd then install a new o-ring on the switch, reinstall it, properly vac the system back down and then fill with the right amount of Freon.
But using a shop is going to be much better since they can remove almost all the oil and then refill to the proper level. It's better for the environment, better for your car and better for you as well.
NitroPT and Gkon like this.
Old 19 Jul 2017, 10:18 am
Default Re: TO MUCH OIL ON A/C SYSTEM
i will do this friday because it is my day off thanks for the advice
francois
Gkon likes this.
Old 21 Jul 2017, 01:56 pm
Problem fix everithing is working fine thanks for the advice !
Francois
rckstein likes this.
Old 21 Jul 2017, 02:00 pm
rckstein's Avatar
Francois
What was done, just a standard a/c service?
A/C system Shiniquiet General PT Cruiser Discussions 9 06 Sep 2014 10:06 am
EVS II Plus system arkansascarnut Sound and Security Forum 0 25 Apr 2008 02:15 pm
how mutch horsepower stage 1 with turbo lite steve smith Stage Turbo Kits 6 08 Sep 2004 12:03 am
a name for my system JaxPT Sound and Security Forum 7 02 Feb 2004 12:04 pm
