Ignition system???
Old 20 Jul 2017, 10:36 am
Default Ignition system???
Good morning, I have a 03 pt and have been experiencing a stumble or jerking condition mostly on hard acceleration and when driving uphill. Also intermittently on the freeway but not very often. Common sense suggests a misfire. However I have recently done a tune up and the are no trouble codes. Any suggestions would be greatly appreciated.
Old 20 Jul 2017, 10:59 am
Handy_Cruiser's Avatar
Default Re: Ignition system???
Take half a bottle of "Heat" fuel dryer and half a red bottle of regular STP gas treatment. Put each in the tank and then top off with fuel. Then see if the problem goes away after a little driving.
Water and or trash in the gas tank will do exactly what you describe and often throw no codes on a PT Cruiser.
Old 20 Jul 2017, 11:12 am
Welcome to the forum.
Has the fuel pressure been checked? Should be 58 +/-5 PSI.
Old 20 Jul 2017, 11:19 am
Fuel pressure has not been checked yet but look into it.
Old 20 Jul 2017, 11:32 am
Get under it and tap the catalytic converter with a rubber mallet. If you hear it rattling, it's coming apart and clogging.
Old 20 Jul 2017, 11:44 am
You are missing to much information for any real "guessing" here!
BEFORE you do anything I recommend to answer a few more questions.
I would first like to ask:
Did this start to happen before your "tune up"?
How did you checked for DTC's?
What and when did you replace for your "tune up"?
What other things did you clean having to do with the engine i.e air filter cleaning the IAC and or TB etc.?
Old 20 Jul 2017, 12:01 pm
The problem began after the tune was done. For the tuneup I replaced the spark plugs and wires, oil and filter, and the air filter. I did not feel that the coil itself was in need of replacing as there were no illuminated mil nor were there any codes pending or stored. Also I used an obd scanner that I purchased a few years ago.
Old 20 Jul 2017, 12:02 pm
I also clean the throttle body but did not tamper with the IAC
Old 20 Jul 2017, 12:53 pm
Start by checking your plug wire connections on the coil and plugs. Make sure they're TIGHT. You should feel a slight click when they're fully seated on the plugs and make sure you pushed them in all the way on the coil. Any chance you left a sensor unplugged after cleaning the throttle body?
Old 20 Jul 2017, 01:07 pm
I have checked the wire connections. They are all right and I did not unplug anything when I cleaned the throttle. I removed the air and the intake manifold which exposed both sides of the throttle. Almost wondering if there is a vacuum hose somewhere that may be cracked or rotted.
No ignition, please help! nickcruiser General PT Cruiser Discussions 9 07 Dec 2015 04:49 pm
%#^&&* ignition key!! wompus General PT Cruiser Discussions 19 02 Aug 2013 04:57 pm
ignition system gitch Tech & Performance Forum 4 26 Jan 2012 07:00 pm
msd ignition oeldisplay Tech & Performance Forum 4 19 Jan 2009 05:32 pm
Ignition Key uskeith Tech & Performance Forum 7 17 May 2008 05:45 am
