The fan does not blow after 1 hour.
Like Tree3Likes
  • 1 Post By ptcruisersteve
  • 2 Post By ptcruisersteve
Old 25 Jul 2017, 03:17 pm
Default The fan does not blow after 1 hour.
My pt cruiser heating problem.
On longer roads, after about 1 hour the air flushes out.
It does not matter if it is heating in the winter or it cools in the summer.
I hear the fan motor going behind the glove compartment.
But there is no air supply at any stage.
The temperature of the air seems right.
Where am I looking for a problem?
Old 25 Jul 2017, 04:46 pm
Default Re: The fan does not blow after 1 hour.
Sounds like an actuator motor for the blend doors is malfunctioning. Good luck fixing that. I'm not sure, but you may have to remove the dash board.
Old 25 Jul 2017, 05:09 pm
If it works on the high speed only then check the blower resister. When it is working is all the speeds working correctly?
When it does not blow air can you hear the fan change speeds when you turn the control speed knob?
Gkon likes this.
Old 27 Jul 2017, 10:16 am
Yes, it works in all speeds.
What controls the mixing door motor?
And where is it located?
Old 27 Jul 2017, 10:38 am
You should check your cabin air filter. If it is partially clogged it might restrict the air coming in after a period of time.
The images below are for a 1st generation Pt Cruiser. You did not specify what year your Pt Cruiser is.
If the cabin air filter is good then it sounds like the blend door isn't moving to allow air to the dash vents as Chuzz posted. Is the air flow restriction limited to the dash vents or also underneath?
First take off the center dash if its only the dash vents and see if the controls are actually moving when you turn the dial.
Then see if you can get under the dash to where the wires actually go and see if they the wire contacts are good.
sanatanadharma and Gkon like this.
Old 27 Jul 2017, 11:50 am
My pt 2000 vintage.
I do not have a cabin air filter.
And the air mixing is good.
On shorter roads, everything works okay.
The problem is only a long way.
No air supply.
But I can hear the fan.
Old 27 Jul 2017, 12:10 pm
Can the fan down power?
For example: thermal expansion, friction, etc.
bad rattle in front end after 1 hour driving nictim Tech & Performance Forum 3 20 May 2013 11:35 pm
5 hour owner getting a P1188 code..should I worry a lot or a little?? enterlaughing General Turbo Discussions 10 03 Oct 2011 07:11 am
