Check Engine Light - no codes???
Like Tree25Likes
Old 26 Jul 2017, 09:50 pm
wingman55's Avatar
Default Check Engine Light - no codes???
So, tonight as I was leaving a concert I had just played in, FIREBALL's Check Engine light came on. When I got a chance, I did the 'key-dance' and: "----- done"
There were no codes. I started it and drove a bit more, and tried again. Same thing.
Maybe tomorrow night I will hook my code reader up and see if it comes up with anything. Any ideas?
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
Old 26 Jul 2017, 10:25 pm
rckstein's Avatar
Default Re: Check Engine Light - no codes???
The "key dance" is reportedly not very reliable for pulling codes, a dedicated code reader is much better.
However, when I was having the TIPM replaced on my PT, both airbag lights were still on. However, my UltraGauge was not displaying any error codes. But before I left the Goodyear shop they also did another scan with their equipment, which I believe was a SnapOn machine, and their equipment also showed no codes.
I was going to the dealership to get the TIPM programmed because Goodyear doesn't have the STARSCAN equipment required to program it. When I got to the dealership, their equipment pulled up 4 active codes and 3 stored. I've seen this before, why would dealership equipment be better than others, and why don't all dedicated code readers pull up all codes, especially those that are stored and active?
wingman55 likes this.
Old 27 Jul 2017, 05:10 am
Well my freind is somewhat correct ^^
Depending on which model Ultra Gauge used it WILL show the monitors.
The key dance really is useless
A Diagnostic scan that can read the monitors is all you need and unless the PCM is failing or there is a connect-ability issue you will find why the light was activated.
Old 27 Jul 2017, 11:18 am
wingman55's Avatar
I'm heading out right now to connect my code reader to see if I find anything.
EDIT:
OK so I hooked up the Code Reader and got P0456, slight evap leak, so I am HOPING it's just a gas cap thing. It's pouring rain (AGAIN!!!) so I'll check it later.
Just had the same code on my Dodge Stratus last week. Hmmmm.
Old 27 Jul 2017, 11:44 am
Fk5 Fk5 is offline
The key dance is not "totally useless". I have never had a time where a dedicated code-reader or my ultragauge show a code that the key dance didn't. I am sure that those methods are better and may occasionally find something the key dance won't. but it is certainly a useful tool if a code reader is not available at that particular moment. I have been using it since the 80's when you had to count the flashes.
2003 GT 5 speed
162,000 miles
Old 27 Jul 2017, 12:25 pm
rckstein's Avatar
EDIT:
Do you have an after-market gas cap? If so, that could be the problem.
I use a locking gas cap and had originally purchased a Stant brand but it kept throwing the gas cap error. Went with an original MOPAR locking cap and no problems since. I am on the second MOPAR cap as they wear out about every 3 years.
Old 27 Jul 2017, 12:29 pm
P0456
What this means is the car is detecting a leak in the fuel system. Not a leak of liquid fuel, rather a leak in the airspace or gas fumes section of the fuel system.
This type of failure often turns out to be a bad gas cap. Sometimes there can be a rust spot on the fuel tank or filler neck or another leak elsewhere in the fuel vapor system.
Old 27 Jul 2017, 12:35 pm
wingman55's Avatar
It's the original stock gas cap.
I did get gas last week, but it's been fine. Like I said, I had the same thing happen on my Stratus.
I will check it out for sure, and THANKS for ALL of the replies.
"MUCHLY" appreciated.
Old 27 Jul 2017, 12:37 pm
rckstein's Avatar
Even MOPAR gas caps wear out after a while, especially if yours is original to the vehicle.
Old 27 Jul 2017, 12:43 pm
The key dance is only giving you a small portion of the information you can get from the computer that you need to fully understand what is happening with your Pt Cruiser. Why waste so much time with the key dance when the OBDII Scan Tool has so much more features including telling you that you are ready to smog your PT Cruiser?
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 16 30 Mar 2015 04:02 pm
check engine light on 07 pt cruiser 3 codes cichlid333 Tech & Performance Forum 7 21 Sep 2013 01:32 am
Check engine light is on, but no codes? wilakers24 Tech & Performance Forum 2 05 Jul 2010 10:47 pm
No Codes yet check engine and oil light won't go off Simple2sing General Turbo Discussions 2 26 Mar 2009 07:26 pm
Check engine light on - & NO CODES?!?! CraigO Turbo Performance 9 20 Dec 2003 02:42 am
