2007 PT CRUISER P0452
Old 26 Jul 2017, 09:59 pm
Default 2007 PT CRUISER P0452
Hi, fuel tank does not vent and MIL code P0452 goes off and on daily. My mechanic already changed front purge valve and the rear NVLD pump and the code is still not fixed. I figure next step is checking connectors to see if NVLD is getting power from PCM? I have a feeling the chassis ground is loose. Anyone know where the NVLD ground wire connects the body of the car or any ideas on what causes a P0452 with no leaks in system?
Old 27 Jul 2017, 06:52 am
Default Re: 2007 PT CRUISER P0452
The sensor is most likely on top of the gas tank ( I don't know for sure), so I would guess the ground wire is somewhere in that area too. Perhaps grounded to the chassis above the tank? Ask your "mechanic" if he had to drop the tank in order to change the sensor. I really don't think this will have any effect on the way your PT runs or performs. It's just a light.
Tags
code p0452
2004 GT error P0452 partyd General Turbo Discussions 3 18 Feb 2014 10:20 am
Just got my 2007 PT Cruiser!! LisaTrump General PT Cruiser Discussions 12 02 May 2009 05:49 pm
2007 pt cruiser jinky General PT Cruiser Discussions 10 15 Jun 2008 07:32 pm
P0452 Fuel Tank Pressure Sensor Error Code dornstar Tech & Performance Forum 0 22 Aug 2007 12:08 am
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage dornstar General PT Cruiser Discussions 0 22 Aug 2007 12:05 am
