PT Cruiser Forum Car Videos
Car Rims
Ins5tall of Water Temp Gauge
Old 01 Feb 2003, 06:43 pm
jramosGT jramosGT is offline
Default Ins5tall of Water Temp Gauge
In my '03 GT I'm planning to istall a boost gauge and a water temp gauge on a A-pillar dual pod. Looking at the 2003 manual, it reads, "The ECT (Engine Coolant Temperature) sensor provides an input to the PCM (Powertrain Control Module).... The ECT sensor provides input for various PCM operations. The PCM uses the input to control air-fuel mixture, timing, and radiator fan on/off times. The PCM uses ECT sensor input to end messages over the PCI bus for temperature gauge operation."
The electrical water temp gauge I have requires me to install a different temp senor in place of the OE unit. From the above that doesn't sound like a very good idea. Any opinion if I can do one of two things:
1. Just tap into the wire of the OE unit to feed a signal to the aftermatket gauge. What info (reistance?) do I need to determine this?
2. Replace the OE ECT sensor with the aftermarket sensor, and tap into that for the PCM feed.
The first sounds more reasonable than the second.
Or should I just install a voltmeter instead of a temp or pressure gauge?
Jumpin' Joe
Onyx Green GT
Jumpin' Joe
Onyx Green GT
Old 01 Feb 2003, 07:42 pm
bobs turbo pt bobs turbo pt is offline
hey joe, the first !!
vB code is On
autometer water temp gauge dfunkdj Turbo Performance 6 23 Jul 2004 05:11 pm
Factory Temp Gauge ZZCruzr General Turbo Discussions 48 16 May 2004 10:03 am
part numbers Punch General Turbo Discussions 5 13 Jan 2004 11:46 pm
Install of Water Temp Gauge jramosGT Turbo Performance 6 18 Apr 2003 03:35 am
AutoMeter Water Temp Gauge jramosGT Classifieds: For Sale/Trade 6 30 Jan 2003 07:11 pm
  Business Credit Cards | Mortgage Calculator | Satellite TV | Mortgage Calculator | Mortgage
