No a/c, no power steering, battery light on.
Like Tree2Likes
Old 02 Aug 2017, 05:23 pm
Default No a/c, no power steering, battery light on.
Hello everyone again. 20 minutes ago as I was coming home the a/c started getting warm then the power steering got stiff and the battery light turned on. I won't be able to get it up in the air til tomorrow but I just wanted a bit of advice? Is it possible both belts broke at the same time? Sounds weird! Could one have broken and thrown the other? Is there some other major failure that would cause this? I was able to make it home about 8 miles from where it happened. 2008 base model automatic. Any tips would be great. Gotta miss a day of work now! Damn Thank my friends.
Old 02 Aug 2017, 05:26 pm
Handy_Cruiser's Avatar
Default Re: No a/c, no power steering, battery light on.
Time to check out those drive belts. And yes, if one breaks or comes off it can make the other one come off too. I'd say there's a 90% chance that your belts off based on what you've said.
Let us know what you find.
CREWZIN and rsrocket1 like this.
Old 02 Aug 2017, 07:47 pm
So I just got under and i found this. Both belts gone and jammed up in the crankshaft pulley and my alternator has a bushing that i think it doesn't need.
Old 02 Aug 2017, 07:50 pm
Was any work done to it recently? You might want to check to make sure the belt alignment is correct otherwise the belts might come off again.
Old 02 Aug 2017, 07:54 pm
i did the head a while back. this has been like this for a while. It is definitely my fault! The Alignment is off. From the pic if you look i cannot tighten the alternator to where it is straight due to that bushing. Should it be there? its preventing the alternator from bottoming out. If i remove it won't there be play? I dun goofed.
Old 02 Aug 2017, 07:59 pm
LionPT's Avatar
Your leaking oil also.
Old 02 Aug 2017, 08:02 pm
HA HA HA HA.. You Think? Too Funny. That's Armor all... No that was actually my next item on the list but this crap killed my list. So does the bushing belong?
Old 02 Aug 2017, 08:16 pm
I would suggest looking at the Factory Shop Manual or part assembly diagram.
I can't get a picture of it on my 2008 Pt Cruiser as I am doing work on one of my other vehicles and I would need to raise the front of the Pt Cruiser to get this picture.
Old 02 Aug 2017, 08:17 pm
rckstein's Avatar
Reading back through all of your posts, it looks like you had the alternator off of the vehicle around 03/16.
This is from the Parts Catalog:
#6 is the nut with the retainer that you can see in the OP's pic, but the sketch doesn't show or mention anything about a spacer.
Old 02 Aug 2017, 08:25 pm
rckstein . Thank you. I think this is the answer. Logically it is. Thank you for the Diagram. im gonna remove it and post a pic after. i Believe this will solve the problem. Thanks too all, will post the results. ::fingers crossed:: donna do it now. few hours work will update tomorrow 9:30pm here in M.I.A.
ENGINE LIGHT Power steering mrmgoo General PT Cruiser Discussions 3 04 Oct 2016 02:47 pm
No power steering and battery light win717 Tech & Performance Forum 8 09 May 2014 10:24 pm
Engine light on / Power Steering issue? Artista General PT Cruiser Discussions 5 13 Jun 2013 04:47 pm
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
