Engine Back In Now What
Like Tree5Likes
Old 05 Aug 2017, 02:53 pm
Default Engine Back In Now What
I finished putting the engine back in last night turn the key and nothing but cranks. It was too late to look at it more but I'm hoping it is just something minor.
2002 Limited Edition 2.4 Auto with 177k Miles
Old 05 Aug 2017, 02:56 pm
Default Re: Engine Back In Now What
First thing I would suggest is to see if you have spark on all cylinders and fuel pressure.
Old 05 Aug 2017, 04:14 pm
LionPT's Avatar
Many users have mixed up the cam sensor & coil plug..they are the same. Try switching them.
Old 06 Aug 2017, 01:17 am
Thanks Lion I'll check it. I didn't get a chance to work on it today but tomorrow morning I'll go over it. I'm assuming at this point it's going to be something simple.
Old 06 Aug 2017, 06:41 am
Since it was dark, I'd suspect you may have missed getting one or two connectors plugged in. Daylight is your friend for this sort of thing. Or a really bright flash light!
Old 06 Aug 2017, 03:57 pm
I went over the connections everything was plugged in. I then checked if there was spark...there's none. I switched the Cam sensor and the coil connector Still no spark. I'll check fuses next. I can't think of what else it could be at this point as there isn't much I haven't replaced under the hood or under the car.
I generally don't have these issues but this seems to be a bit of a mystery.
Old 06 Aug 2017, 05:35 pm
What kind of shape are the ground connections on the driver side fender in? Check for broken wires there.
Old 06 Aug 2017, 05:38 pm
I would suggest disconnecting the Camshaft sensor and try to start it. It could take up to ten seconds for the engine to start as it will be in limp mode without the Camshaft sensor. If it starts then you might have an ignition timing issue.
Old 06 Aug 2017, 08:05 pm
After my last post I went out and tested the cam sensor...It was bad. Replaced the cam sensor hit the key and perfect. The cruiser is back on the road and running great. Thanks everyone
rckstein and Gkon like this.
Old 06 Aug 2017, 08:16 pm
rckstein's Avatar
Glad to hear that your PT is back up and running
What a coinkydink that the sensor went bad while you had the engine out. Maybe that's all that was wrong with your PT to start with
Gkon likes this.
Can PT front seat back upholstery be interchanged, non air bag to air bag seat back. ptprice General PT Cruiser Discussions 4 06 May 2017 02:59 pm
Back again Check engine light now mahgninnuc68 Tech & Performance Forum 3 19 Feb 2012 04:33 pm
Hump back hatch back conversion... Metaltwister Exterior Accessories Forum 48 14 Sep 2011 11:00 pm
better put your back seats back Ctown General PT Cruiser Discussions 0 26 Feb 2006 11:21 pm
