p0340 and p0325 codes
Old 06 Aug 2017, 12:01 am
Default p0340 and p0325 codes
at first I was just getting the p0340 code, I messed with the wires and removed and cleaned the cam sensor and cleared the check engine light, and the code went away for a week or so. now I get both cam and knock sensor codes, doesn't it just seem normal that the cam sensor failure would change the timing and cause an ignition knock and cause that knock sensor code. so fixing the cam sensor would eliminate the knock sensor code automatically? Just a thought. Thanks for any input. 2005 non turbo, new timing belt, water pump, head gasket, and cooling system disposable items.
Old 06 Aug 2017, 01:27 am
Default Re: p0340 and p0325 codes
I would suggest checking the wiring going to the Camshaft senor and if that is okay to check the Camshaft sensor itself.
The link below has a thread on another member that had the same codes.
2005 Cruiser error codes p0340/p0325
Old 06 Aug 2017, 02:01 am
ya the wires going to the cam sensor were butchered, each had 2 or 3 areas where they scraped the insulation off and didn't even put tape over them, they were all touching, i separated them and taped them up and that seemed to fix it for awhile. i thought that was done, but it came back. I got a buddy with a breeze sitting in his yard, 'm gonna swap that cam sensor and see how it goes, he has a spun rod bearing but no codes. thanks ill check that link,
2005 Cruiser error codes p0340/p0325 Iryss9 Tech & Performance Forum 29 04 Aug 2013 07:13 pm
P0340/p0522 codes.. wheeluh_boy Tech & Performance Forum 14 06 Jul 2013 06:11 am
codes p1391, p0340 soyomb Tech & Performance Forum 6 29 Oct 2012 08:45 pm
Codes p1684 and p0340 xodeflepgirlox Tech & Performance Forum 1 08 Oct 2010 07:46 pm
