Alternator belt tuning.
Like Tree16Likes
  • 3 Post By VsandFords
  • 1 Post By rob302
  • 4 Post By RVC
  • 1 Post By Handy_Cruiser
  • 2 Post By Handy_Cruiser
Old 08 Aug 2017, 02:45 pm
RVC RVC is offline
Default Alternator belt tuning.
I read in the 01-04 pdf shop manual this was the way to go for proper belt tightening. Is this how the rest of you do it? In the process I discovered the nearby household A/C compressor hums along at about 42 Hz.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 08 Aug 2017, 03:13 pm
VsandFords's Avatar
Default Re: Alternator belt tuning.
Man, am I lost! This old Texas country boy tightens it until it feels " just about right and good enough for the girls I hang with!"
Old 08 Aug 2017, 03:20 pm
rob302's Avatar
me too. i just tighten it until it feels OK to me. a little loose is better than too tight.
too loose might make it squeak when you start it, where as too tight will ruin the alternator bearings fairly quickly
i have my mustangs belt just tight enough that on a cold damp day, it may let out one baby chirp when i turn the key in the morning. that's perfect for me
maybe i over think it as well..
VsandFords likes this.
Old 08 Aug 2017, 03:26 pm
RVC RVC is offline
Well, yeah that's kind of the way I was. But hey, if the manual says between 235-247 Hz then I recon (that's Texan) that's what I'll give it. Wasn't that hard either. Just happened to have a tuning app on my Kindle Fire that worked like a champ. My belt is now tightened enough to give 241 Hz. I feel like such a pro! Doesn't take much to make me happy.
Thanks for your response.
RVC
Old 09 Aug 2017, 07:02 am
Handy_Cruiser's Avatar
Here's the instructions from the service manual. You don't really need the Miller 8371 microphone wand nor a DRBIII. Any simple instrument tuner that can read out in Hz will work.
L2fish likes this.
Old 09 Aug 2017, 07:24 am
rob302's Avatar
In figure 8... Can you even see that in real life?
Old 09 Aug 2017, 07:35 am
Bore scope, maybe?
If like where I work, the young engineers get the job of writing the manuals so they don't always know under what conditions the real item is serviced.
rckstein and rob302 like this.
Old 09 Aug 2017, 07:44 am
RVC RVC is offline
Figure 7 refers to the "tuned" alternator belt. Figure 8 is about the belt for the A/C compressor and the Power Steering pump. That belt has an automatic tensioner which is shown.
Old 09 Aug 2017, 07:53 am
rob302's Avatar
I know, I've had the pleasure of changing it
Old 09 Aug 2017, 07:54 am
Yep. Me too, twice.
My question on Figure 8 is if a technician could actually see the marks on the tensioner, what would he or she do if the marks didn't line up? The manual doesn't say and there's no adjustment. Should he just try another belt or what?
PS: I know it's actually to check for stretching on a used belt and/or to possibly help indicate other problems like a bad idler pulley bearing. But it just seems strange.
Alternator belt help! supernasro Tech & Performance Forum 19 03 Apr 2014 07:38 am
help with alternator belt xctxthexundeadx Tech & Performance Forum 1 03 Apr 2014 07:23 am
Tightening Alternator Belt falconut Tech & Performance Forum 6 27 Sep 2013 04:54 pm
Help with Alternator belt defflepp1 Tech & Performance Forum 7 20 Sep 2013 09:55 pm
Alternator Belt Question edisapimp Tech & Performance Forum 2 22 Jun 2007 01:50 am
