2008 rear brake caliper question
Like Tree4Likes
  • 1 Post By cjb340
  • 1 Post By chuzz
  • 1 Post By Busted_PT
  • 1 Post By NitroPT
Closed Thread
Old 08 Aug 2017, 05:45 pm
Default 2008 rear brake caliper question
Hi all,
I searched the forum for an answer but my search skills are about as lacking as my mechanic skills. Anywho...
I am replacing the rear pads on my 2008 pt cruiser. Do I need the special caliper tool to compress the pt's caliper? Or will a standard c clamp be sufficient? I needed the special tool for my 2010 town & country and was not prepared.
Thanks for your time and info!
Old 08 Aug 2017, 07:50 pm
rcktpwrd's Avatar
Cool Re: 2008 rear brake caliper question
Not sure about an '08 but on my '01 I used a C clamp to compress the piston, just like the front calipers. I doubt they changed that over the years...
Joel
www.rcktpwrd.com
Old 12 Aug 2017, 07:30 pm
Default Re: 2008 rear brake caliper question
I just did my 2007 2 days ago. I used a c clamp. I had to replace my parking brakes because at one time the park brake pivot lever must have froze up and worn down the shoes. Make sure while you are in there you check that these pivots are loose and lubricated. You'll see them when you pull off the rotors. Service manual says to remove the hub to change the parking brake shoes but I did not need to.
let me know if you have any other questions.
Handy_Cruiser likes this.
Old 12 Aug 2017, 10:49 pm
I have never used a c clamp on my calipers. I know that's the normal way, but I have always done it the quick way. Before I unbolt the caliper, I simply use a small prybar or flat head screwdriver through the slot on top of the caliper and pry against the top edge of the rotor. It is super quick and I don't have to mess with c clamps or spreader tools or whatever.
Old 13 Aug 2017, 12:06 am
DO NOT DO THIS unless you want to take the chance damaging brake parts!
This has to either be a joke or a response to see if I would respond.. WOW! OMFG!
Old 13 Aug 2017, 05:46 am
^^ I've seen a LOT of people do it like that over the years, Lynn. I don't say anything, but I wouldn't buy a used car from them, unless I got a very good deal!
NitroPT likes this.
Old 13 Aug 2017, 09:10 am
Some brake calipers pistons are made out of some type of ceramic material. So be carful not to pry on the lip of one of these. Not sure if these were used on a PT.
NitroPT likes this.
Old 13 Aug 2017, 09:35 am
rckstein's Avatar
If he was using anything to pry with, wouldn't he put it between the old pad and the rotor to push the piston back? If so, you don't care about the old pad and you could put something on the rotor to prevent any damage, correct?
Old 13 Aug 2017, 10:15 am
RICK you DONT PRY brake parts !
chuzz likes this.
Closed Thread
Rear brake caliper guide pin bolt size? channelcge General Turbo Discussions 2 23 Mar 2017 07:12 pm
Brake Question After Freeing Stuck Caliper chuzz General PT Cruiser Discussions 13 15 Aug 2016 05:56 pm
Painted brake caliper question? Michigander Wheels, Tires, Suspension 7 15 Sep 2014 10:17 pm
Possible brake caliper mod honu Members PT Project 12 22 Jun 2013 12:35 pm
PT GT Brake Caliper Question 2005PTGT Tech & Performance Forum 5 29 May 2010 10:11 am
