fuel pump/starting problems
Old 10 Aug 2017, 08:30 pm
Default fuel pump/starting problems
Hi guys I have a problem with my wifes 06 PT. it won't start the fuel gauge reads empty there is power back to the plug for the pump. Voltages at the plug are Big blue/ orange stripe wire 11 volts key on, small blue/ white stripe 11.83 volts key on or off, big black wire 9.82 volts key on 5.42 volts key off, small black/ green stipe no voltage. I tried hooking it up directly to another battery using another plug connecting the big blue /orange stripe to positive post and the big black to the neg, the other two wires not hooked up, turned key on the car started and runs normal fuel gauge says full. Any ideas on what the problem is or what direction to look in ? Thanks
Old 10 Aug 2017, 08:45 pm
Default Re: fuel pump/starting problems
I would suggest you check the ASD relay and see if it is working properly.
Old 10 Aug 2017, 09:14 pm
Hi ptcruisersteve thanks for the responce that was my first thought but In the fuse panel there is no asd relay as a matter of fact there is no relays there at all and I can't find any other place they would be? the relays are listed at the parts store but I can't find them anywhere
Old 10 Aug 2017, 09:19 pm
LionPT's Avatar
Drivers side right corner.
Old 10 Aug 2017, 09:42 pm
Thanks a million I'll try that tommorow
Old 11 Aug 2017, 06:29 am
LionPT's Avatar
You can swap the ASD with 1 of the fan relays...left side of radiator.
Old 11 Aug 2017, 05:25 pm
Well I tried swapping the asd with a new relay ,its not the problem I am wondering why the big black wire on the pump plug has voltage on it are the 2 black wires not grounds ? and the other two supply power to the pump and sending unit ?
Old 11 Aug 2017, 05:32 pm
The fuel pump control is done through the TIPM. The TIPM receives an input signal from the PCM. Once the TIPM receives the signal, it will output a 12 volt supply to the fuel pump module turning the pump on.
Does your Pt Cruiser have the TIPM? It should be right behind the air filter.
This is link to another thread that had the TIPM issue. The member repaired the TIPM.
Fuel pump relay
Old 11 Aug 2017, 06:38 pm
Yes its identical to the photo you posted I don't have the fuse layout (what each one is for ) though. Can I just hot wire the fuel pump and bypass all the trouble ?
Old 11 Aug 2017, 06:59 pm
I don't have enough knowledge to give you advice on this question. Maybe some other members can help you. You might send Partyd a private message and ask him what his advice would be. Please do post what you find out.
Tags
fuel gauge, fuel pump, fuel tank, wiring, wiring harness
Car not starting; fuel pump? ShineHigh247 Tech & Performance Forum 7 17 Mar 2017 08:55 am
New fuel pump, but now no fuel to front? bundixlake Tech & Performance Forum 14 21 Mar 2014 09:41 pm
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
Fuel pump going out? desarae77 Tech & Performance Forum 15 02 Apr 2013 07:43 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
