Engine dies on occassion and stops and goes at odd times
Old 16 Aug 2017, 03:01 pm
Default Engine dies on occassion and stops and goes at odd times
hello
about three weeks ago I took my PT Cruiser (touring edition) for my Missouri safety inspection (passed) but almost immediately on the drive home the check light engine came on...the next day when I started my car up the ligth was off, so i was a bit concerned, but not overly so
Then while waiting at a stop light my car just abruptly died. Idling fine, quiet engine, it just....stopped. But thankfuly started right back up again
then on a number of fairly long trip (20-30 miles) the car would start "chugging" dropping in RPM's then back up again, up and down, not going over 45 ...I would pull over, restartthe car and everything was fine for the rest of my trip
Most telling, this also happened simultaneously when my fuel light came on once I was under a quarter tank...once I illed the tank, the check engine light wen off
Most recently i was at a drive thru and the engine died. this time it didn't start right up just turn over and over and over....I had to push it to a parking spot and after ten minutes it was able to start and I was going to be able to get home. but looks like i can't avoid the shop now
at first, due to something similar with a ZX@ Escort i had i thought it may have been an exhaust hose/oxygen sensor....but talking with co workers they think it may be the fuel pump/filter (especially with the simultaneous issue when I got low on gas)
What do you all think? how confident are you this is the issue? my local shop wants to charge ike 80 dollars for a diagnostic. and if it's not something I can fix myself I would like to skip the diagnostic and just tell them what needs to be fixed
thank you
Old 16 Aug 2017, 04:00 pm
Default Re: Engine dies on occassion and stops and goes at odd times
Welcome to the forum
You might want to start a introduction thread as a new member.
In the mean time spend a little time about many other member that have had issues like you described. There is not much that has not happened and threads started over the years.
WELCOME and Forum Rules
Old 16 Aug 2017, 04:08 pm
Apologies. the "stopped in the drive thru" problem happened on my lunch break. As I am stil at work I haven't had the chance to explore much
Old 16 Aug 2017, 10:06 pm
Exclamation Re: Engine dies on occassion and stops and goes at odd times
I would suggest you invest in buying an OBDII Scan Tool that will tell you what your engine trouble codes. Post what the codes are.
Engine dies at idle area49 General Turbo Discussions 22 06 Aug 2017 05:46 pm
Car dies multiple times on highway terry3396 Tech & Performance Forum 6 28 May 2015 06:13 pm
-Very- Rough Idle and engine dies + hot air purplecruiser Tech & Performance Forum 6 27 Feb 2015 11:09 am
01 Engine dies after getting warmed up GHampton General PT Cruiser Discussions 20 03 Feb 2015 05:45 pm
Engine starts and runs briefly then stops. dkbjjpick Tech & Performance Forum 1 15 Sep 2013 08:58 pm
