2004 GT TURBO...DEAD
  • 1 Post By Handy_Cruiser
Old 19 Aug 2017, 12:54 pm
Default 2004 GT TURBO...DEAD
Wife's gt died while driving..got it home..pulled two codes P0340 (camshaft sensor)...and P0016 (crankshaft sensor)..since they are related..looks like it's a timing belt issue..belt has approx 80,000 miles on it, 149,000 on the car, engine turns over...but won't start..all other functions are fine, lights, horn..etc...hoping it might just be a sensor problem...lot easier to repair..anyone have a better idea on this than me ?? thanks..pj
Old 19 Aug 2017, 01:15 pm
Handy_Cruiser's Avatar
Default Re: 2004 GT TURBO...DEAD
There's always a small chance something else has happened, but what you described is classic timing belt failure for a PT Cruiser.
To make sure, just pull the little plastic dust cover off the time belt sprockets. Chances are you will see a broken belt or sprockets that don't turn when you crank the engine. If all seems good, remove #1 spark plug and get the piston all the way up during the compression stroke if you have any compression. Lack of compression will also confirm belt failure with the other signs you gave. But if there is some compression at all, chances are the visible timing mark on one or both of the cam sprockets will be pretty far off. This means the failed belt as slipped but not broken.
myckee likes this.
2004 turbo ECM Bryanjones General PT Cruiser Discussions 7 13 Jul 2017 11:26 pm
Dead turbo? CruiserMike General Turbo Discussions 8 12 Dec 2016 09:47 am
2004 PT Cruiser Cigarette Lighter DEAD DAFUS General PT Cruiser Discussions 4 20 Feb 2016 03:26 pm
2004 Turbo TallahasseeGT Classifieds: Want To Buy 0 22 Jul 2014 01:46 pm
2004 turbo chillincruiser General Turbo Discussions 17 17 Mar 2006 04:39 am
