Middle motor mount stripped bolt
Like Tree5Likes
  • 5 Post By Mopedmonkey
Old 20 Aug 2017, 08:42 am
Default Middle motor mount stripped bolt
While putting the PT back together I stripped the torx bolt threads. Just got another from a junk yard but I couldn't get the big metal bracket. I'm debating pulling it to see if those threads are messed up too unless others have stripped the same bolt with the plate threads being ok. I know it's a long shot but I figured I would ask. Thanks!
Old 20 Aug 2017, 10:11 am
Default Re: Middle motor mount stripped bolt
I ended up pulling the bracket, cleaned up the threads and ran the new bolt from the back all the way through. Worked like a charm and it's back in.
Old 20 Aug 2017, 12:57 pm
_PTGT03's Avatar
make sure it was torqued to spec and didn't strip. if it's just tight enough, it will back out over time and fail completely. it will cause the engine cradle to fail, and taking out your upper and lower mounts, possibly the cv joint as well.
i had to remove the centre mount, drill out the threads and replace it with an insert. because the thread debth was longer than one helicoil, i had to stack up two and then cut off the last coil of thread.
Broken Middle Motor Mount Bolt chromer don Tech & Performance Forum 16 02 Apr 2017 07:00 pm
Motor Mount Bolt ? red98gt Tech & Performance Forum 7 10 Oct 2016 09:31 am
mid- motor mount bolt willy13 General Turbo Discussions 15 30 Mar 2016 11:32 pm
Help with Middle pass side motor mount Leannaluv Tech & Performance Forum 15 08 Sep 2014 02:07 am
Broken motor mount bolt madeupofwires General PT Cruiser Discussions 1 24 Jun 2014 03:58 pm
