P0120, P0122, p0340 p0129 p0335 Code Issues?
Old 22 Aug 2017, 10:49 pm
Default P0120, P0122, p0340 p0129 p0335 Code Issues?
Lemme guess... you did a timing belt or head gasket job and now you have this problem?
Check to make sure you didn't switch your cam position and coil pack connections. They're the same fit and you could accidentally switch them around.
If that isn't your problem, then I wish you luck (because I've read that rabbit hole and it's deep).
Thanks to NitroPT and some obscure posting on 2carpros.com for the tip.
Error Code P0335 firemedic1560 Turbo Performance 14 15 Jan 2012 12:42 pm
Engine light on, code P0129 cannesman Tech & Performance Forum 6 30 Apr 2011 12:33 pm
Code P0129 ?? BPfromFLA Tech & Performance Forum 4 07 Aug 2010 05:56 pm
2004 GT with error code P0122 deborrini General Turbo Discussions 4 03 Jul 2007 07:19 pm
