2006 Fuel pump issue
Like Tree4Likes
  • 1 Post By mkoski
  • 2 Post By mkoski
  • 1 Post By Handy_Cruiser
Old 28 Aug 2017, 08:46 am
Default 2006 Fuel pump issue
Year: 2006
Motor: 2.4 Non-Turbo
Model: Base
Service history: Unknown 160,000 Miles
Concern: No Start
Codes present: P0499
Picked up this Cruiser to use as a work car a couple of weeks ago. Drove it home. upon closer examination determined it could benefit from some cooling system maintenance along with a fresh battery.
Installed a fresh water pump along with the timing belt kit and cam seals.
post assembly it would not start.
Sprayed some starting fluid into the throttle body and it started, stumbled for a few seconds as the computer seemed to re learn and then ran smooth as glass. The engine runs fine at all RPMs so long as I manually feed it fuel.
When the ignition key is put into the run position the relay below the windshield on the driver's side closest to the fender does go click after 2-3 seconds, however, I do not hear the fuel pump. Had my son go under the vehicle and both carefully listen and put his hand near where I suspect the pump is in the tank. Turned key to run no noise from the pump at the tank.
I did remove one ground connection during the water pump procedure it is on top of the upper lateral motor mount bracket I'll try cleaning it tonight.
User Chuzz had warned of issues with the TIPM in this model year I have thus far only checked the fuses all appear good and I note no corrosion on the TIPM fasteners for what it's worth.
I need to check and see if the pump will run when power is supplied at the rear connector. Does anyone know what two wires at the connector are used to test the pump?
Old 28 Aug 2017, 09:20 am
rckstein's Avatar
Default Re: 2006 Fuel pump issue
Old 28 Aug 2017, 09:26 am
LionPT's Avatar
Originally Posted by mkoski View Post
Year: 2006
Model: Base
Concern: No Start
Just because the relay clicks...doesn't mean it's good...it still might not make contact. The relay you mentioned is the Auto Shut Down Relay
You can swap out that relay with 1 of the 2 fan fan relays on the left side of the radiator to check. Do Not swap it with the relay next to the ASD, that relay is the Starter.
Old 28 Aug 2017, 03:47 pm
Originally Posted by rckstein View Post
Here's a copy of the Service Manual and Parts Catalog from my Dropbox links, you'll probably be needing them:
https://www.dropbox.com/s/9av5weyw5j...anual.pdf?dl=0
https://www.dropbox.com/s/y9kie6gh30...talog.pdf?dl=0
Just want I needed Thanks.
rckstein likes this.
Old 28 Aug 2017, 03:48 pm
Thanks. Yep, I swapped in a known good relay yesterday just hoping.
Old 12 Sep 2017, 09:25 am
Issue resolved:
Damage to wiring between firewall and pump
Cleaning grounds resolved the PO499
Old 12 Sep 2017, 09:28 am
Handy_Cruiser's Avatar
Issue resolved:
Thanks for coming back and letting us know. And congratulations on getting that PT back on the road.
Asking for help in understanding error code/fuel pump issue InfamousCruiser General PT Cruiser Discussions 2 15 Jan 2016 06:07 am
2006 PT Cruiser Fuel Pump Relay Sweaty_AZ Tech & Performance Forum 2 09 Jun 2014 08:11 pm
Fuel Filter / Pump issue ??? Tyrhera General PT Cruiser Discussions 21 17 Jun 2011 08:31 pm
Ignition Issue !!, Fuel pump, filter or MAP sensor? somarillw General PT Cruiser Discussions 3 17 May 2011 06:40 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
