New Water Pump and Timing Belt now NO HEAT....Help
Like Tree4Likes
  • 1 Post By JDK52
  • 2 Post By ptcruisersteve
  • 1 Post By JDK52
Old 09 Sep 2017, 08:54 pm
Default New Water Pump and Timing Belt now NO HEAT....Help
Frustrated PT owner....Help! My PT was over heating so new water pump, and
timing belt.....now no heat. Heat was fine before. Anyone have any suggestions. Single mom needing advice...lol
Old 09 Sep 2017, 09:07 pm
JDK52's Avatar
Default Re: New Water Pump and Timing Belt now NO HEAT....Help
If having no heat is the only concern there is a good chance that there is air in the heater core.
The remedy is purging the cooling system.
There are many threads on this site with the specifics on how to accomplish that essential task.
Seems that is your situation, and a good next step.
ptprice likes this.
Old 09 Sep 2017, 09:15 pm
I would suggest checking to see if you have air in the engine coolant system as JDK52 suggests. After the engine has cooled off take the radiator cap off and see if the coolant is up to the top. If not fill it up and see if you have heat. If you do have heat after filling it up you need to have an engine coolant pressure test to see if you have a leak if it has been a while since the timing belt has replaced.
When was the timing belt replaced?
DId they replace the thermostat? The thermostat can get damaged and not work properly after overheating.
ptprice and JDK52 like this.
Old 09 Sep 2017, 09:40 pm
JDK52's Avatar
Here is a link to a relevant thread:
Bleeding air from cooling system
Old 10 Sep 2017, 06:52 am
VsandFords's Avatar
Welcome to the forum from Texas.
Please go to the new members section and introduce yourself and tell us about your Cruiser.
As you can see, we have great people with tons of knowledge.
Timing belt, Water Pump Peterbylt Tech & Performance Forum 18 12 Jan 2015 10:08 am
DIY Water Pump/Timing Belt tooter1 Tech & Performance Forum 16 06 Oct 2012 09:18 pm
Timing Belt/Water Pump sonocativo General PT Cruiser Discussions 6 31 Jul 2012 04:11 pm
Timing Belt/Water Pump Help MamaCruiser Tech & Performance Forum 5 20 Oct 2011 12:15 pm
Timing Belt/Water Pump mybubbles65 General PT Cruiser Discussions 3 04 Oct 2011 04:47 pm
