Recommend a Fuel Pump
Like Tree6Likes
  • 3 Post By VsandFords
  • 1 Post By rob302
  • 1 Post By NitroPT
  • 1 Post By ArthurKill
Old 11 Sep 2017, 06:03 pm
Default Recommend a Fuel Pump
Replace just the pump/motor or do the entire assembly?
Any brands better than others? Prices are all over the place on these things, wondering what the general consensus is, thanks!
2005 - 2.4 Normally Aspirated
Old 11 Sep 2017, 06:17 pm
VsandFords's Avatar
Default Re: Recommend a Fuel Pump
Replacing the assembly is easy, quick and complete. You replace all hoses, strainer and filter.
One and done!
Old 11 Sep 2017, 06:56 pm
rob302's Avatar
I replaced just the pump. A member here sent it to me. I had to unclick 3 plastic tabs to get it apart. If you can take the cover off a relay, or take a switch apart without ruining it, by all means this is the way for you. I even reused the non-reusable clamps. It depends on your skill level. If you're confident, just get the pump. It's easy. If not, but the assembly for 3x the money. I think changing just the pump is easy and wouldn't hesitate to do it that route again.
SPLNeon likes this.
Old 11 Sep 2017, 11:35 pm
I personally replace the pump with a performance aftermarket unit.
I just pictured it (I think) on the latest purchase thread.
Old 12 Sep 2017, 07:38 am
Thanks for your answer.
I'm not looking at the same breadth of price disparity as you have experienced. In some cases/brands, the price is very close and in a few instances (AutoZone) the price is exactly same for both. Not sure why?
But saving money is always paramount -- that's why we work on our own cars.
I'm no mechanical pro but I've already taken apart the old unit just out of curiosity, so I'm confident I can complete the task.
I figured that buying the entire assembly will give me the sending unit (fuel gauge floaty thing) and that's a plus.
Question: does the assembly contain any other components other than the float, filter and the motor? Is there a pressure reg or anything else like that?
Thanks!
Old 12 Sep 2017, 08:15 am
Old 12 Sep 2017, 08:19 am
Questions: does the assembly contain any other components other than the float, filter and the motor? Is there a pressure reg or anything else like that?
Thanks!
Read the description from the parts suppliers you are thinking about buying the unit from. Most give good descriptions of what you get.
Example of the one I just bought:
E7190M Fuel Pump W/Sending Unit For 04-09 PT Cruiser 2.4L From 11/10/2003 Turbo
tem specifics
Condition: New Cross Reference Part Number: SP7190M 5114547AC, 5114547AD, 5114547AE,
Include: Fuel Pump+sending unit+strainer+O-ring,Regulator Interchange Part number1: 5114547AF, 5114547AG, 9533057
Brand:
Powerco
Vehicles: 2.4L L4 Turbocharged From 11/10/03
Item Name: Electric Fuel Pump Module Assembly Working Voltage: 12V-13.5V
Manufacturer Part Number:
Does not apply
Interchange Part Number2: 402P7190M 402P7190M
Warranty: 1 Year Other Part Number: 5114547AH, 5114547AI,
Package includes: Fuel Pump Module, Pressure Regulator, Sending Unit, Float, Reservoir
Cross part number:
E7190M SP7190M 5114547AC, 5114547AD, 5114547AE
Feature:
This is a brand new fuel pump and well packaged in box, It built to meet or exceed OEM specifications, can direct replacement for your original OEM fuel pump.
Our modern production equipment and manufacturing technology, strict production process quality control, ensures the superior product quality and customer satisfaction.
Fk5 likes this.
Old 12 Sep 2017, 04:52 pm
tem specifics
Brand:
Powerco
Does not apply
Cross part number:
Feature:
Many of the assembly's I looked at online did not have detailed information, and did not annotate exactly what came with the assembly. That's why I asked. Many thanks either way.
Turns out, I didn't have a choice -- I thought I had more time but some things came up and I had to do it today. All I could get from my local guy was the motor, so I just did that.
The one I got was branded "Precise Genuine Parts 402-P7207" - $47 bucks, wholesale.
I had just as much trouble getting the retaining ring back on as I did getting it off. I think the hose that came with this motor was a little long. I might have to go back and trim a 1/4 inch. I was only able to get 2 out of 3 clicks on the ring and although, it'll never let go, it will bother me.
But, I cut the access hatch so going back is no biggie. Thanks all for the education.
I'm looking to fabricate a door for the new access hatch, any ideas?
3rcruiser likes this.
New fuel pump, but now no fuel to front? bundixlake Tech & Performance Forum 14 21 Mar 2014 09:41 pm
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
fuel pump rob342 Tech & Performance Forum 13 18 Sep 2012 05:16 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel pump nevinsrt Turbo Performance 4 15 Aug 2008 09:03 am
