Horrific Grinding noise when engine is running
Old 16 Sep 2017, 10:39 pm
Default Horrific Grinding noise when engine is running
Alright......... even more problems. I'm using a used t350 from a junkyard, also a used clutch. In between my transmission and motor there has been a horrific grinding noise, it sounds like when you spin something too fast and it slows down with vibration. I don't think it's my rods because it happened literally over 5 minutes and I wasn't even running my motor hard. It also doesn't have a knocking noise. When cranked with the starter ( pulled coil pack ) it makes a clunk sound, but still doesn't sound like bearings. Please help me. I'm almost done with my project and I don't want to ruin it already.
Old 16 Sep 2017, 10:43 pm
Default Re: Horrific Grinding noise when engine is running
By the way, the motor is a 2.4 turbo, my starter is a 41te starter, my trans is from an 03 neon, a t350 3.55 with neon transmission components, and the transmission is full and not leaking any fluid. The flywheel is rusty but is solidly bolted. One more thing is that a tooth from the clutch spring is bent inward but only slightly. It doesn't sound like the sound is coming from there either
Old 17 Sep 2017, 12:30 am
Handy_Cruiser's Avatar
Does the noise change when you engage the clutch?
Old 17 Sep 2017, 07:07 am
Sounds like maybe the starter bendix is staying engaged in the flywheel teeth. Maybe the starter is different?
Old 17 Sep 2017, 08:10 am
rob302's Avatar
I'll guess loose flex plate or flywheel
Old 17 Sep 2017, 10:19 pm
I suspect that both rob and chuzz may be right. I just hope it isn't the rods
Old 18 Sep 2017, 07:13 am
I've been monkeying around with cars since I was a kid. I've NEVER heard grinding noise from rods. They knock when they're getting ready to seize or turn loose. Get under it and check the gravel shield, the flywheel and the starter. Get back to us.
Old 18 Sep 2017, 07:58 am
Fk5 Fk5 is offline
Which rusty flywheel do you have? The turbos came with a weird two piece flywheel. Mine started to come apart and made it almost impossible to take in and out of gear while running. Stopped it shifted like butter. The two parts were moving at different speeds and monkeying things up. Didn't make much noise though.
How wide are these flywheels supposed to be? I think those measurements are pretty important and you are using a turbo engine in a non-turbo car with a Neon trans that wasn't in PTs if IIRC. Sounds like a place to start. Not sure why anybody would ever put a car together with a rusty flywheel...
2003 GT 5 speed
162,000 miles
Old 18 Sep 2017, 10:52 am
Any shavings in the bell housing area. If so steel or aluminium?
Old 19 Sep 2017, 03:54 pm
No shavings, play in the flywheel. Transmission from the neon bolts right on to the turbo motor. The N/A PT uses the same manual trans as I have in here. I'm trying to figure out an easier way to drop the trans as well
Grinding noise webstertroy General PT Cruiser Discussions 6 26 Feb 2016 11:14 am
Grinding noise from engine SACruizer Tech & Performance Forum 19 17 Dec 2014 11:53 am
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
Another Grinding Noise... bjagd02 Wheels, Tires, Suspension 3 01 Nov 2010 09:01 am
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
