Replacement 2.0l manual tx/NV-T350 drain and fill plugs?
Old 23 Sep 2017, 04:24 am
Prostheta's Avatar
Default Replacement 2.0l manual tx/NV-T350 drain and fill plugs?
Hi guys,
It's been a while since I checked in! We've been slowing going over each important wearing part of our PTC, and we're at the point where we'll be replacing all of the fluids. So, the gearbox....
The girl is up on the lifts today so we'll be looking out for an "ATF" sticker on the box (ATF+4) however it seems like our year might be Mopar M.S. 9417?
So, if we don't find out whether the box contains one or the other, how can we find out?
....which takes us onto the subject of drain and fill plugs. I haven't found a source for spares yet....I'd rather have a set on hand in case either strips out, and preferably to replace the drain plug to prevent any possibility of leakage issues. As everybody says, fluids and plugs are cheaper than boxes.
As a side issue, I take it that the power steering fluid will be straight ATF+4 as well, so here's to hoping that we haven't got weird premium MOPAR unicorn squeezings and ATF+4 in the box....
2001 2.0l PT Cruiser Touring Edition
Mods: New gear knob, blue LED re-lighting, token chrome bits.
215'000km (55.9% distance to the moon, 71.7% of a second at light speed, Usain Bolt running for 200 days)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use" - Søren Kierkegaard
"What can be asserted without evidence can be dismissed without evidence" - Christopher Hitchens
Old 23 Sep 2017, 06:04 am
Prostheta's Avatar
Default Re: Replacement 2.0l manual tx/NV-T350 drain and fill plugs?
My greatest concern is over the choice of MTX box fluid. ATF+4 is readily available here in Finland, however, sourcing MS-9417 is going to be a real bear. You think it's expensive over there....? Try squeezing a few quarts of that stuff out of Santa's sack up here in the wilds of northern Europe.
@valkyriemc pretty much states flat out that we shouldn't bang ATF+4 in the box, and given the chances of it ruining our box through quick choice....yeah....also don't want to lose our precious rare box juice from a potentially leaky 16yr-old drain plug!
Manual Transmission Fluid Change
drain plug T350 trans wb2kki General PT Cruiser Discussions 4 14 Apr 2014 12:27 pm
Power flush vs. drain/fill for tranny. sgraves Tech & Performance Forum 4 01 Jul 2013 01:49 pm
Transmission drain and fill issue!!! 2002ptcruiserwoody723 Tech & Performance Forum 10 01 Oct 2009 09:02 am
MOPAR ATF +4 Drain & Fill How Many Quarts? lmmegt Tech & Performance Forum 13 23 Sep 2009 07:30 am
Coolant Drain & Fill Help lmmegt Tech & Performance Forum 3 07 Sep 2009 10:11 pm
