Check Engine W/ No Codes Crank W/ No Start
Old 01 Oct 2017, 12:35 am
Default Check Engine W/ No Codes Crank W/ No Start
2006 Pt cruiser 2.4 touring turbo started having rough idle issue where the check engine light started blinking at idle. now it wont start and blinks 11 times and chimes every time I try to crank it over
put a 3130lat obd2 scanner on it
battery voltage at 12.4v
when starting it drops down to 8.9- 10v
There were no global diagnostic DTC's set
on the Chrysler level the only thing set was a code for battery disconnect
the key fob works fine and has a new battery in it
A yellow Led was lit on the 3130 which means that vehicle’s emission monitors have not run their diagnostic testing, no Freeze Frame Data is stored or Powertrain DTC's. It also says Emission Related Engine Dtc's but nothing shows when scanned.
Im not sure where else to check
Old 01 Oct 2017, 04:04 am
_PTGT03's Avatar
Default Re: Check Engine W/ No Codes Crank W/ No Start
10 volts is too low when cranking. shouldn't go below 10.5
Old 01 Oct 2017, 06:17 am
Remove the air box and clean the battery terminals of all corrosion or acid build up on the terminals. Charge the battery and try again.
You loose cranking amps with dirty or loose connections.
Next your starter may be shorting on the inside and causing a large amp draw.
Turn the headlights on try cranking the starter, if they go dim or starter just clicks, it power problem.
Make sure all ground and power connections are clean and tight.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Oct 2017, 07:48 am
Yank the battery and take it somewhere and get it load tested. Sounds like you've got a dead cell in it.
Old 10 Oct 2017, 01:14 pm
Thank you all for your input sorry for the delayed response, I didn't think about the battery because it was new but ill definitely clean the terminals.
Ive been driving it just to work and back and have come across new issues that may be battery related, im going to get that replaced today ( warranty )
P0300- cylinder 3 misfire
P0340- cam position sensor bank one ( cleared this code , it went away for a couple of days then came back on after the the car started running rough on an extremely hot day )
P0882 - Tcm Power Input Low
P0700 - Transmission Control System (Mil Request)
P0218 - High temperature operation activated
Ive changed the spark plugs for the misfire they have a gap of -0.050 NGK Gp platinum part# 3381
all 4 wires tested between 1850 ohms and 1920 ohms so I believe im good there, I have yet to test the coil but will do that tomorrow .
I believe battery might be related to the TCM power input now that you guys have suggested to change it, I will update the thread with more info
Old 10 Oct 2017, 01:45 pm
I would suggest resetting the DTC's with an OBDII Scan Tool after taking care of the battery voltage issue and then post what diagnostic trouble codes come back.
Old 10 Oct 2017, 01:46 pm
Fk5 Fk5 is offline
I don't know what the cause is, but P0300 is not cylinder 3. Cylinder 3 misfire is P0303. P0300 is a "random cylinder misfire" It is more likely to be something general, like the wiring, voltage, coil, your cam position sensor, than a specific cylinder would be.
2003 GT 5 speed
162,000 miles
Old 10 Oct 2017, 02:12 pm
P0300 - Multiple Cylinder Misfire
Possible Causes:
1. Fuel system problems exist
2. Erratic Camshaft or Crankshaft Sensor signals
3. Ignition system problems exist
4. Engine mechanical problems exist
5. PCM has failed
Old 10 Oct 2017, 08:54 pm
ok everyone , replaced the battery. car now requires cranking for several seconds while pumping the gas to turn on , it has an extremely rough idle and the lights flicker in park and shuts off sometimes when i try to reverse.
The original misfire code was p303 it said cylinder 3 specifically my apology's for the misdirection
average engine rpm 172
all previous DTC's cleared the new ones are:
p0340- camshaft position sensor circuit bank 1 sensor 1
p1603- PCM internal Dual Port Ram Communication failure
p0325- knock sensor circuit 1
U0101 Lost communication with TCM
p1603 again
p0340 again
Ive still yet to check the coil pack
Old 10 Oct 2017, 10:59 pm
_PTGT03's Avatar
i'd rather be there in person to diagnose this problem. when you have multiple strange issues happening at once it's hard to troubleshoot online. however with an experienced eye and proper technique it can really be something simple.
Tags
check, code, crank, engine, start
Check Engine Codes PapaJohn Tech & Performance Forum 24 18 May 2014 01:06 pm
No Crank, No Start, cannot get codes airobats Tech & Performance Forum 5 01 Oct 2013 04:29 pm
Different check engine codes Jkraft0531 Tech & Performance Forum 1 06 Apr 2013 10:06 am
No Codes yet check engine and oil light won't go off Simple2sing General Turbo Discussions 2 26 Mar 2009 07:26 pm
Engine check on / Codes Krzysztof General PT Cruiser Discussions 1 16 Apr 2007 09:37 am
