Clunking in right front
Old 01 Oct 2017, 08:33 pm
RVC RVC is offline
Default Clunking in right front
I've been searching for this issue for a while and finally discovered there is significant play between the right tie rod and to whatever it connects to when it disappears into the rubber bellows on the steering gear.
This definitely needs to be repaired as the play is considerable. Is this a servicable item for a home mechanic? Must the steering gear be removed to enable replacement or repair of the problem in question? I have the downloaded pdf service manual and a quick glance through it hasen't revealed much so far - perhaps it will as I progress farther into it.
If there are those who could give some guidance it would be appreciated. This is my only transportation.
Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Clunking in right front area RVC Wheels, Tires, Suspension 3 01 Oct 2017 10:34 pm
front end clunking noise Carl48 General PT Cruiser Discussions 11 28 Nov 2016 07:47 am
Clunking noise in front RoseDust Tech & Performance Forum 4 19 Sep 2011 10:21 pm
Front end clunking noise discovering06 Tech & Performance Forum 1 26 Feb 2011 07:01 pm
