Clunking from front end after garage work
Like Tree2Likes
  • 2 Post By rob302
Old 05 Oct 2017, 04:23 am
Exclamation Clunking from front end after garage work
I took my PT cruiser in to get front brakes, rotars and a right side hub bearing assembly kit installed as the bearing were shot. Immediately afterward the front end clunks under my feet while driving and right turn causes bumping sounds. Is it possible that the mechanic broke something. Wouldn't he have noticed a problem with the suspension while it was on the hoist.
Old 05 Oct 2017, 05:05 am
Default Re: Is it possible
Where should I go to get a response to my post. I'm a new member
Old 05 Oct 2017, 06:39 am
Default Re: Clunking from front end after garage work
I've moved your post to the TECH section. If anyone has an answer to your question they will respond after my post. We encourage all new members to post in the WELCOME part of the forum and introduce themselves there.
Old 05 Oct 2017, 07:04 am
Unless you asked for the suspension to be checked, I doubt that the "mechanic" did anything more than what you asked for. I'd suggest checking the sway bar bushings and end links. If they're worn or loose, you can definitely feel the thumping under your feet. Just take it somewhere else this time.
Old 05 Oct 2017, 07:10 am
rob302's Avatar
i'd bring it back and let them look. mechanics are people and do occasionally get interrupted and forget to tighten things. i'd think they'd rack the car and look for free since it occurred only after they've touched it.
LionPT and Grasshopper77 like this.
Old 09 Oct 2017, 06:55 pm
the control arm bushings are a weak link on PT's, you may want to have those and the ball joints inspected.. stay away from the chain stores...
A trusty garage for Timing Belt work. MrMister Southeast PT Forum 7 15 Oct 2017 11:45 am
Clunking in right front RVC Tech & Performance Forum 0 01 Oct 2017 08:33 pm
front end clunking noise Carl48 General PT Cruiser Discussions 11 28 Nov 2016 07:47 am
Clunking noise in front RoseDust Tech & Performance Forum 4 19 Sep 2011 10:21 pm
Front end clunking noise discovering06 Tech & Performance Forum 1 26 Feb 2011 07:01 pm
