Stripped Oil Plug Fix
Like Tree7Likes
  • 5 Post By dsab
  • 2 Post By Overdrive
Old 08 Oct 2017, 04:52 pm
Default Stripped Oil Plug Fix
Last night I changed my oil and when I removed the plug an old helicoil came out with it. Seems someone thought the oil plug in the aluminum pan held the engine in and stripped it out at some point. I can't say here what my 1st thought was.
So I started going over ways we would fix stripped out threads and I remembered we usually got lucky by replacing the regular oil plug with a longer bolt with the same thread, Since the oil plug is short and the oil pan hole is threaded all the way through a longer bolt will utilize those unused threads. If it's a steel pan this won't be an option
I checked the oil plug threads and they are 14mm X 1.5. Went to our local Ace Hardware and bought a bolt I think in length was 45mm. Before running it in I put a new crush washer on it and problem solved.
However, if anyone one should over tighten and strip it out again it won't be such an easy fix.
I wanted to pass this along as a stripped out aluminum oil pan plug is probably more common than you'd think.
2002 Limited Edition 2.4 Auto with 177k Miles
Old 08 Oct 2017, 10:10 pm
Default Re: Stripped Oil Plug Fix
I had the same problem. If one makes oil changes at "Precision Auto" then pretty soon there will be a stripped oil drain plug. I installed a drain valve like this CHRYSLER
Since my threads were stripped, I had to use JB weld. No issues since then.
podo2000 and dsab like this.
2001 PT Cruiser Limited Edition 5-Speed MT, stock. Second owner since 06/2016
Old 08 Oct 2017, 10:14 pm
Handy_Cruiser's Avatar
Hey, I've got one of those now. Wonder where it came from?
Old 08 Oct 2017, 11:46 pm
_PTGT03's Avatar
unfortunately you can't expect much from previous owners and having mine stripped, i just ordered a new oil pan and i'm about to change it out soon.
Stripped oil drain, oil pan question Faulkster Tech & Performance Forum 8 10 Jul 2017 08:25 am
Stripped spark plug threads MJKnight Tech & Performance Forum 12 21 Jul 2015 07:53 pm
Stripped thread Stempy Tech & Performance Forum 3 18 Nov 2012 01:05 pm
STRIPPED SPARK PLUG HOLE chuck2112 Tech & Performance Forum 5 01 Mar 2010 09:52 pm
Spark plug threads stripped in head. What are my options? WalterZoomie Tech & Performance Forum 6 12 Nov 2009 03:45 pm
