P0120 Throttle Position Sensor
Old 19 Oct 2017, 07:32 am
Default P0120 Throttle Position Sensor
Hello
After being serviced my 2003 2.2 diesel developed P0120
I've had the throttle position sensor replaced (crazy money...) but the code keeps coming back.
I've reset it and sometimes the EMS light stays off for 150miles, sometimes 5miles.
Other times the EMS light goes out by itself!
Any suggestions?
Thanks
Michael
Old 19 Oct 2017, 08:02 am
rob302's Avatar
Default Re: P0120 Throttle Position Sensor
I would suggest this is a wiring issue. There's only 3 wires. First to check would be the ground wire. Voltage high? Voltage low? The connector may require inspecting. The problem will be easier to find once the code is constant
Old 19 Oct 2017, 11:25 am
These are some of the common causes of P0120 on a 2.4L gas engine for a Pt Cruiser.
1. Sticking throttle return spring
2. MAP or TPS connector corrosion
3. Misrouted harness causing chafing
4. Bad TPS
Old 22 Oct 2017, 08:30 am
I had the same repetitive code on a Neon. I ended up checking continuity of wiring between the TPS connector and the PCM (car's computer) connector. There was high resistance in the wire that feeds +5V to the TPS. I spliced in a new wire to bypass the bad wire, and that fixed it. Somewhere deep in the wiring loom is a broken wire.
Throttle Position sensor, where is the rascal? txsbigfoot General Turbo Discussions 15 09 Feb 2016 06:15 pm
Throttle Position Sensor Related to P0340/344? Jayou Tech & Performance Forum 8 15 Jul 2015 02:03 pm
Cleaning the Throttle Position Sensor sscanlan Tech & Performance Forum 3 17 Jun 2012 04:36 pm
Throttle position sensor Cruiser73 Tech & Performance Forum 4 23 Mar 2011 12:09 pm
Throttle Position Sensor (TPS) readings Bman05Ltd Tech & Performance Forum 5 29 Aug 2007 06:59 am
