Error Codes 700 & 882
  • 1 Post By rckstein
Old 19 Oct 2017, 11:33 am
Exclamation Error Codes 700 & 882
New PT owner. I own a 06 Turbo Auto. Recently the two trans codes came up 700 & 882. I was told this could be as simple as a bad wire or more. Has anyone had these two codes together. Just bought my Cruiser and pretty stressed. Husband is an old school mechanic (not good with computers on newer cars) but can fix with the right info. So trying to research this and get some answers. Any help is greatly appreciated.
Old 19 Oct 2017, 01:08 pm
Default Re: Error Codes 700 & 882
Here is the Alldata disg procedure for this DTC
I would suggest checking the wire harness going to the TCM under the battery. Some members have been able to fix it by repairing the wires or cleaning the wire connectors going to the TCM.
Old 19 Oct 2017, 01:40 pm
rckstein's Avatar
They have a Gen2, the TCM is in the PCM, not a separate module as on some of the Gen1.
Old 19 Oct 2017, 02:00 pm
Good catch! I met to say to check the wires going to the transmission solenoid/ TRS assembly at the transmission.
Old 19 Oct 2017, 02:25 pm
Thank you we will try this
ABS error codes?? ptbruiser223 Tech & Performance Forum 4 04 Sep 2015 07:02 am
Error codes: Luvour04ptgt Turbo Performance 3 25 Aug 2013 09:16 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
Error codes hidinginparadise Tech & Performance Forum 2 23 Jan 2012 08:52 am
2 error codes at once heshdog Tech & Performance Forum 9 02 Oct 2011 05:07 pm
